Question about Lands Phones
I want to add a name to the phone book of my Uniden phone. There is room for 100 names, so far I have used 25. When I select ''Phone book' and 'Select' I get the message 'Memory Full'. How do I fix that? How do I type a space between two words? Thanks
  • 1 more comment
  • Arnold Gelderman Nov 19, 2008
    My phone appears to be a Uniden 2.4. Possibly also 'DCT 646 Series'. Both indications appear on the manual's cover.
    I keep getting emails that there is a solution to my question, but when I click on the link I am taken to the very first 'solution', which was a request for information, which I provided. Please clarify.
  • Arnold Gelderman Nov 22, 2008
    I have posted this question zeveral days ago bur received no answer. Please give me a solution or refund my $9.99. Thanks.
  • 370 Answers
Have you cleared the caller id log lately? if not delete the caller ID log and see if there is memory now.
Posted on Nov 22, 2008
  • 790 Answers
Hello!!
Try resetting ur phone
1. Disconnect Battery from handset 2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Posted on Nov 19, 2008
    Sergeant:
    Champion:
  • 347 Answers
Hello Edzard,
Could please tell us the brand and model of your phone?
  • Santiago Vallejo
    Santiago Vallejo Nov 19, 2008
    Hello Edzard,
    If looking in page 36 of your manual dosent help you, check if there are 100 adresses stored. They might be repeated, or with no characters. Just make sure there are only 25 names. If so let me know,
    Good luck,
    Dahaka
  • 734 Answers
What was the model number?
    Sergeant:
    Champion:
  • 435 Answers
Hi, Could you please let us know the model number?
Thanks,
  • 1,183 Answers
Could let us know the exact model of the Uniden phone that you are using
Thanks
Proton
  • Mandeep  Singh
    Mandeep Singh Nov 19, 2008
    Try deleting to enteries from the phone book and try inserting the numbers again.
    Editing or Erasing a Stored Name, Phone
    Number, Distinctive Ring, and Speed Dial
    1) When the phone is in standby mode, press phonebook.
    2) Press ring/vol/∧ or ring/vol/∨, or the number keypad
    to view the phonebook locations (see "Viewing the
    Phonebook" on page 40).
    a. Editing the Stored Data
    1) When the phonebook location to be edited appears,
    press select/􀀍. S t o r e / E d i t N a m e appears.
    2) Follow the steps 3 to 7 under "Storing Phone Numbers,
    Names, Distinctive Rings, and Speed Dial" on page 36
    to complete the editing operation.
    3) Press select/􀀍. You will hear a confirmation tone.
    b. Deleting the Stored Data
    1) When the phonebook location to be deleted appears,
    press menu/del.
    D e l e t e M e m o r y ? appears.
    2) Press ring/vol/∧ or ring/vol/∨ to move the pointer
    to Y e s .
    3) Press select/􀀍. You hear a confirmation tone.
    D e l e t e d ! appears in the display.
    If the problem persists , there is a problem with the hanset and would require service or replacement . You can contact uniden support on the following number
    1-800-297-1023.
    Thanks
    Proton
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone System...
I purchased a Uniden model D1688 and I don't know how to put favorites into the phonebook.
Entries can be added from the base or the handset. The CID button is on the right of the control ring; the phonebook is on the left of that ring.
If you want to add a number from the Caller ID list to the phone book, press CID and use the up/down arrows to navigate to the call that you want to add. Then press Menu/Select. Select the line Store into Pb and press Menu/Select. You will be at the Edit Name Screen for the phonebook.
To enter a new item from scratch, press the Phonebook button. Then press Menu/Select and select the Create New submenu. Press Menu/Select and enter the name of the contact using the alphabet on the key pad. (For C, press 2 three times.) Press Menu/Select and enter the phone number as it is dialed (including a 1 if needed). If you need to add a pause in the number, press Redial/Pause. However, the entire number must be less than 20 digits (including the pause). Press Menu/Select again. If you enter the number from the handset, you will be prompted to select a ringtone to always use when you get a call from that number. Press Menu/Select again. Then press End (on the handset) or Play/Stop (on the base) to exit the menu system.
Uniden has the manuals available at their site, either from the product page or the support page. All DECT phone manuals are here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manuals are listed in numerical and alphabetical order. The direct link to the D1688 manual in English is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1688-2om.pdf .
I hope this helps.
Aug 30, 2011 | Cell Phones
My phone dect 6.0 uniden rings when someone calls but will not dial out
Hello :
Maybe you need to program the phone .
Here I'll tell you how :
  1. Press the Down main navigation button and press Menu/OK. The main navigation button is in the center of the keypad and is cylindrical in shape.
  2. Press either the Up or Down main navigation button until "New Entry" appears on the display.
  3. Press the Menu/OK button and "Enter Name" will appear on the display.
  4. Enter the name using the keypad. Enter the names the same way you would enter text in a text message on a mobile phone. For example, to enter the character "H," press the 4 digit twice. Use the labeling on the buttons to guide you.
  5. Press the Menu/OK button after entering the name and "Enter Number" will appear on the display. Enter the phone number using the keypad.
  6. Press the Up or Down navigation button to select "Save" or "Go Back" and then press Menu/OK. The entry is now programmed. Press the goodbye button; it's the button with the phone icon on a cradle.
  7. Press the Down navigation button and the first alphabetical number is displayed. If you keep holding the button, the phone will scroll through your phone book alphabetically.
  8. Press the button with the phone icon on it (not the goodbye button) to dial the number associated with the phone book entry.
I hope that will help .
rate if useful please !
Feb 22, 2010 | Uniden DECT 6.0 Cordless Telephone...
How do you add a phone number to the address book of a Uniden cor
Hello there and welcome to lfete at Fixya, the Support Team
Normally you add a new number to the phone in the feature contacts. Go to there and select add new and type the number name etc. :O)
Hope that helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
Jan 02, 2010 | Uniden Cordless Phone
I have only 26 names stored in the handseet and it
It uses a shared memory. The caller ID and the Phone Book share the same memory. Clear out the caller ID and you will be able to store more names/ numbers in the phone book.
Mar 20, 2009 | Uniden Cordless Phone
Cannot edit stored phone numbers
goto phone book hit menu find the number and or persons name you want to edit edit the number hit ok to get to the number or you can do the easier way
delete there name and number and put it back in with the right digits
May 30, 2008 | Uniden Cordless Phone
Uniden power max 2.4 ghz
I had the same problem but figured it out. For some dumb reason, Caller ID numbers count against your total phonebook memory. So if you just delete all your Caller ID numbers (press the "Caller ID" button and then the "delete" button) then you'll be able to store new numbers in your phonebook.
If I could get my hands on the Uniden engineer that is responsible for this, I'd smack him! :)
May 17, 2008 | Uniden Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
