my dryer has stoped producing heat. It still tumbles and the air flow feels strong but the clean filter light is on although i have cleaned the filter.
-   hi i have same problem on my candy cic 60 tumble dryer ,the clean filter light is on,tho i have cleaned it,it rotates and blows but wont heat up ive bin advised to change the heater element,but have read that it could be a safety measure,that is stoping it heating up,so changeing the element wont cure the problem?what shud i do? clean everything again more thoroughly?-   rosco_uk69
hi i too had that problem,when an engineer looked at it the thermostat,element were ok,he suggested that there was a blockage in the air flow,i took the whole thing apart ( i had nothing to lose ) cleaned it with a hoover very carefully then with a clean dry paintbrush,there is vents underneath the dryer if these get blocked the dryer blows cold air, its a saftey measure so that the fluff dosent catch fire ! i hope this helps,mine has run ok for 3 months now.
I also have to say that the handbook instructions for cleaning the lint filter are inadequate. Whils it easy to run water through the sides, and straight forward to clean the rear vents with a small srewdiver or similar it is not easy to even see any blockage at the front grill due the front plate blocking your view. I did however have a scrape at the front vents with a right angled soldering scraper. To my astonishment EVERY vent was blocked solid with ancient lint. I removed about a half pound of the stuff from the front alone! I have now decided to make this thorough cleaning of the filter a monthly event.
Comments:
Jan 03, 2009
- EUREKA !!!
Thoroughly cleaning the front vents of filter has worked! I now have normal heat. As I said in solution 2 above the front of the filter needs special attention. The top three openings can be cleaned with a small screwdriver or similar, but the bottom four need something narrow with a right angle to scrape them clean. I used a right angled soldering scraper (a set of six double ended soldering scrapers are available for about £4.99 from Maplin Electronics), but I suppose a bit of stout wire bent to a suitable shape will do just as well.
The on off switch will not engage and switch the dryer on. There is a crackle noise in the timer...
(More)
The on off switch will not engage and switch the dryer on. There is a crackle noise in the timer when trying. This occurs when the timer is between its drying settings. The on off switch will engage when the timer is outside its drying settings. You then have to turn the timer to the drying time you want. Regards, David.
I put a new belt on but in the process, two wires came away from the timing dial. Does anyone know...
(More)
I put a new belt on but in the process, two wires came away from the timing dial. Does anyone know the colour combination for the wiring?
