Question about HP DesignJet 500ps (42 in.) InkJet Printer
Replacement carriage belt for HP DesignJet 800
Need to replace the carriage belt for a HP DesignJet 800 printer 24"
  • 32 Answers
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
Posted on Nov 19, 2008
Hp designjet 800 error 2:10
System Error: 02:10
Is a carriage failure.
Get someone to look at it, possible carriage assembly replacement
Oct 27, 2011 | HP DESIGNJET T770 Printer
HP Designjet 800ps 24". How
Instructions are usually supplied with the belt, however if you are looking for the manual, you can find it here!
Jul 05, 2011 | HP DesignJet 800ps InkJet Printer
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
HP 500ps showing error is System error 86:01
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
If this error code appeared but was NOT caused by a paper jam, then try the following:
* Too much friction in the Slider Rod. lubricate the Slider Rod.
* The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly
Apr 16, 2010 | HP DesignJet 500ps InkJet Printer
Carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Trying to find a schematic assistance to an error reported "system error 86:01" for my hp designjet 800.
System Error: 86:01
Problem
Description:
Corrective Action: If this error code appeared but was NOT caused by a paper jam, then
try the following:
 Too much friction in the Slider Rod. Enter the Printer Information
utility (→ Page 4-26) and check the Scan-Axis usage. If the
percentage is close to 100%, then lubricate the Slider Rod.
Service Station/Aerosol Fan Assembly → Page 8-52.
 Perform the Carriage Movement test → Page 4-8. Okay this is the error code direct from the service manual. if lubricating the slider rod does not resolve this issue then you have other problems. more than likely the carriage belt is in need of replacement. check inside of printer for debris. check under the carriage assembly. see if you are able to move the carriage assembly smoothly from side to side. hope this helps.
Mar 12, 2009 | HP DesignJet 800 Printer
Replacement carriage belt for HP DesignJet 800 Printer
It is not recommended that the user replace the carriage belt, on any HP printer. Any damage caused by the user, won't be covered by the warranty and will likely result in a completely useless, but very expensive doorstop. Or paperweight..
I do believe your printer has since been discontinued for support, however only an HP Customer Service Representative would be able to confirm that. I would suggest phoning HP for technical support or to at least confirm whether support is available.
Even if your printer is no longer a) under warranty, which I suspect it's not, or b) out of support completely, they may be able to provide you with a list of Authorized Service Providers (ASPs) within your area.
1-800-474-6836
Best Of Luck.
Nov 19, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
HP DesignJet 500ps (42 in.) InkJet Printer Logo
733 people viewed this question
Ben Johnson
