Question about Indesit W 123 Front Load Washer
Indesit evolution we 123
Our washine machine is showing f-08 it fills with water then drains straight away any ideas we have moved house and it was stood in shed for 2 weeks could it be damp
  • Indesit Master
  • 3,463 Answers
Hi.
the error code means that the heater relay is not working.
You will need to call an engineer.
If you call hotpoint, it will cost you over £100-00.
Better to call a independant if you can find a good one.
Posted on Nov 20, 2008
Water runs in and straight out of my washing machine
drain pipe has to be as high off floor as the washer is tall .
Jan 30, 2016 | Washing Machines
Washing machine wont fill up
you ahve a kink, or clog in the hose
Oct 04, 2009 | Indesit W 123 Front Load Washer
Tumble dryer not working
SOUNDS AS THOUGH YOUR HEATER ELEMENT HAS GONE..
IT IS POSSIBLE TO FIX IT YOURSELF BUT VERY COMPLICATED, CALL OUT FROM A REPAIR PERSON IM AFFRAID, COMBI WASHER/DRYERS ARE RENOWNED FOR THIS & ALSO BEARING KITS
May 22, 2009 | Indesit W 123 Front Load Washer
Washin machine not filling
The problem is probably the water fill valve is defective. Make sure that the door is shutting properly, as it will not fill if the door isn't shut.
Post a comment if you need more help.
Thanks,
Tim
May 08, 2009 | Indesit W 123 Front Load Washer
Indesit w127 error code f-08
Error F08 is indicating that the heater relay is stuck or cannot be activated or the contact has welded in the relay.
The only thing u can do yourself, is to check that the heater is o/k, if u can determine that it is , then u have no option other thancalling an engineer.out.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Indesit W 123 Front Load Washer
Error code on washing machie
The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too.
Jan 03, 2008 | Indesit W 123 Front Load Washer
Indesit DE73 showing A08 fault code
Sounds like it has overflowed at some stage. Ensure the filter is cleared and then rock the dishwasher backwards. Any trapped water will drain out and the safety valve will reset. i had similar and this was what the indesit technician did.
May 21, 2007 | Indesit 24 in. DE73 Evolution...
Indesit W 123 Front Load Washer Logo
217 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
