Question about Mongoose Exile 26 Men's Full-Suspension Mountain Bike
Chain Rubbing In summer I bought a Mongoose bike. The chain rubs on the gear shifter and drives me nuts when riding. Only paid $200 for the bike and would like to see if I can fix the problem without taking it to a repair shop and spending an arm and a leg. Any suggestions?
    Problem Solver:
  • 11 Answers
Kevin:
I'm not sure if it's rubbing on the front or rear shifter. The front is more common, so I'll try that first. The shifter pushes the chain left (lower gear) and right (higher gear) to shift - if it's rubbing, then it may be trying to shift. If it can't be fixed by using the shifter directly, which you've probably tried already, you'll probably need to adjust the cable.
There are two ways to adjust the cable, with a barrel adjuster and with a wrench. The barrel is the piece between the cable housing (plastic tube the cable goes through, usually black) and the shifter. If it's the front shifter, it will be the one one the left of your handlebars. Try 'unscrewing' the barrel a little bit at a time. It may be off in either direction, but 'unscrewing' will tighten the cable, and since you bought the bike in the summer, it's likely that the cable has stretched and become loose since then.
Count the number of turns and try only 1 at a time, watching to see if the rubbing goes away. If not, return it to where it was by turning the same number of turns the other way.
Without knowing whether it's the front or rear, which gear it's in and which side it's rubbing on, this is my best answer. Let me know and I'll adjust my advice!
Dan
Posted on Nov 20, 2008
Why do i have a slight rubbing/ticking noise from very low speed coasting on my bike?
lots of reasons .......could be chain rubbing on chain guide if it has a chain,or may be worn out chain,.........could be tire rubbing ....check and make sure both tires are evenly spaced between forks and swing arm.....if it has a chain guard make sure chain is not rubbing on guard....Best way to check is to put it on it's double kick stand and start the bike put it in gear and let the tire spin at idle and listen and look for the problem.
Jul 16, 2014 | 2007 Suzuki Bandit 1250
I cannot get my chain to stop coming off. How do I keep the chain from slipping off?
Loosen the nut that holds the back wheel and pull it back until the chain is tight and then retighten the nut. If when the chain is tight, the wheel is not on the rear frame, you need to take a link out of the chain.
Jun 25, 2014 | Mongoose 20" Mode 90 Boys Freestyle Bike
Huffy boys bike makes clicking noise
does it make the "clicking" noise when coasting, pedaling or both? If it is only when pedaling, check to make sure the cranks are not rubbing on a chain guard or hitting the frame, if not then the chain is probably too tight and it is the gear cog teeth meshing with the tight chain. Loosen the rear axle nuts and slide the rear wheel forward slightly, this should take care of it. If the noise happens while coasting then one of the wheels could be rubbing on the frame intermittently, or the hub bearings could be too tight (also making it difficult for small legs to pedal) and the bearings are crushed and flattening making the "clicking" noise as they are being ground up.
Apr 21, 2014 | Huffy Pro Thunder Boys 16-Inch BMX Bike
Putting the chain on
While the bike is in riding position loop the chain on the back sprocket. If this is a single speed bike then place as much of the chain as you can on the top of the front sprocket. Once it is partially threaded you can crank pedal around a half a turn and the chain will pop on the rest of the teeth.
Oct 10, 2012 | Mongoose 24 Inch XR75 Bike
Bought my son a Mongoose Rebel at walmart, but when pedalling, it feels like the crank is skipping forward. how do I correct this?
Until you resolve this please don't let your son ride the bike.
Do you mean skipping as in the chain is advancing over the cog or chainwheel teeth? It sounds like you don't have sufficient tension on the chain. After loosening the rear axle nuts, pull the wheel evenly back to make the chain snug but not tight, then tighten the nuts and make sure the wheel is straight, centered and not rubbing the frame.
Jan 17, 2011 | Cycling
Hi...just put together my son's new Bike (20'' Boys' Mongoose Rebel Freestyle Bike) and I noticed that when pedaling backwards, it's not smooth, and sounds like something is rubbing or grinding (pedaling...
It sounds as though the chain is too tight. Check to see when it is "freewheeled" if the chain gets tighter. Generally this will happen because the chain ring (front sprocket) was not perfectly aligned with the "spider" (thing it bolts to). You can loosen the chain a little and see if this helps. Be careful because you don't want it so loose the it comes off while riding. What I usually do is adjust the tension of the chain with the sprocket in the tight spot. Kind of tight but without the "grinding" feeling.
Good luck.
Dec 22, 2010 | Mongoose Cycling
Mongoose tactic mountain bike / loose crank on chain side. How to tighten.Chain ring moves with it. Makes clicking noise.
The crank has to be removed to tighten the nut that holds the gear on. I assume that is your problem is with the chain gear on the sproket that is loose
Apr 21, 2010 | Pacific International Mongoose 26 in. Mens...
I have a moutian bike an the gears want change the back gears are slipping so i cant ride
Try this: shift into the highest gear and release the derailleur cable at the derailleur. Pull it taut and retighten the pinch bolt. Give it a thorough washing and degreasing, too. A clean drivetrain is a happy drivetrain. Remember to use bike chain oil, not anything else, on the chain and ONLY on the chain.
Nov 19, 2009 | Mongoose 2009 Firball 24" Boy's Moutain...
My shimno sora front derailler shifts perfectly to the small and large chain set cogs, but on the middle, the chain rubs along the cage.
Set the rear derailleur to the lowest gear (big cog) and the front to the lowest gear (small chain ring). Disconnect the derailleur cable. Screw in the adjuster for the cable tension all the way (this adjuster is on the shifter of a mountain bike or the down tube of a road bike). Pedal to make sure the chain is not rubbing on the derailleur cage. If it is, adjust the "L" setting on the derailleur until the chain moves by without touching the cage. Now pull taut and reattch the cable and shift the front to the big ring while pedaling. If it does not shift up well or completely, hold the shifter past its normal shift and adjust the "H" screw so that the derailleur allows the shift. Shift into the highest cassette gear and keep pedaling. The chain should not be touching the front derailleur's cage when you pedal. Adjust with the barrel adjuster until the chain moves freely without touching the derailleur cage.
i hope this helps
-matthew
Oct 30, 2009 | Cycling
CHAIN REPLACEMENT
I think I can help. Place one end of the chain over the rear gear (doesn't matter which one, the biggest) and adjust the lever or twist ring on the handlebar so the derailleur lines up in a straight line with it. Pull the chain from the rear sprocket down and over the pivot wheel and back over the bottom wheel so it looks just like this S and the end comes forward. Join the chain links. Place the chain over a couple front teeth and turn the pedal carefully until the chain seats on the front sprocket.
May 05, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Mongoose Exile 26 Men's Full-Suspension Mountain Bike Logo
195 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
