Question about Sony KP-53V80 53" Rear Projection Television
Sony tv that flashes red
Hay guys I have a Sony projection tv. This sucker flashes red a few times then turns it self off. It acts like its getting hot. It has been doing it more often now. If you wait a few minates it will turn back on for an hour or so then do the same thing. The red light flashes on the front. Is the red bulb going bad? Thanks for your help.
  • Sony Master
  • 5,138 Answers
Re: Sony tv that flashes red
(1) you have a bad capacitor next to hori output transistor and stopit you have both your hori output shorted and bad capacitor 1200pf 2k volts.
Posted on Feb 01, 2008
0 characters
3 Points
Sony 60" wega tv it just turned it self off when i
it's telling you to replace the projection lamp, it has burned out,
Feb 28, 2013 | Projection Televisions
My kf50we610 tv will not come on only flashes green a few timws then flashes red
First, look to see if the red is blinking a specific number of blinks or not.
Second, how long since the lamp this set uses was replaced and if it was, was it a Sony or Generic lamp?
Dec 13, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Sony HDTV get sound when turned on but no picture small red standby lite in front flashes for a few seconds then turns it self off
Count the number of flashes in between a slight pause and see if its a 9 blink error or not. Then let me know how many blinks the red light is doing and I will assist you with the issue
Aug 10, 2011 | Sony KP-51WS520 51" Rear Projection...
I have a 60' sony wega r60xbr1 i just had a new light engine installed last night the tv was never turned on afterwards . I turned it on the screen come on shut off imediatly the red led flashes 4 times...
LOOK IF YOURS IS A SONY I had a sony grand wega 60 inch with the same problem as many tv turns on shuts off the red led FLASHED 4 TIMES. it is a heating issue if one of the three fans inside are not turning when the tv is on even on the first few seconds of turning it on the tv will send a fault code of four flashes . Then the tv shuts off so it wont burn its self up or damage the optical block. all with this same problem of 4 flashes take a flashlite and make sure your fans are turning if not that is your 4 flash problem. I hope this helps someone and if it does i have done my job .
Dec 29, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony lcd projection tv in self diagnosis mode. 4 red flashes
This is a fan error take the back off the set and see if the fan is turning.
Sep 13, 2009 | Projection Televisions
My sony tv Comes on some times but then some times does not
On most of your rear projections you got GUNS and if there out of allignment or overheat you will get this error and it will need to be serviced.
Apr 22, 2009 | Sony KP-61V85 61" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-53V80 53" Rear Projection Television Logo
103 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
