Question about Dell E176FP 17" LCD Monitor
Display stuck at 640x480 16-bit after a reformat. Dell E176FP Monitor, will not change. No option to select Properties etc in the display settings. No option to select monitor type. I don't remember having this much difficulty the last time I reformatted it. Can anyone help?
  • lseewer Dec 07, 2008
    I have the same problem and can't determine which driver is the correct one to reinstall.
  • richardm783 Jan 27, 2009
    i can't find a free driver. can u help?
  • 105 Answers
You need the driver for the video. The default driver will just do minimum resolution.
Posted on Dec 16, 2008
Dell e176fp resolution wont display properly on windows 7
Try to change the bit to 32 true colour and size
Jan 02, 2014 | Dell E176FP 17" LCD Monitor
How to get rid padlock Dell E176FP 17" LCD Monitor Dell monitor lock display and all display button not functioning ang monitor power too
You can follow these steps:
1.Click on the menu button in front of the monitor
2. Select OSD settings
3. Select OSD lock
4. Then choose Yes or No to lock and unlock it
Hope this helps
Thanks
Dennis
Oct 26, 2011 | Dell E176FP 17" LCD Monitor
How do i alter the setting that turns my monitor off after 5mins if i leave the room or have not pressed a key etc etc
Hi. If you are using Windows XP (most common OS right now), right-click on any empty space on your desktop and select "Properties" then click "Screen Saver" tab, click "Power" button, "Power Schemes" will pop-up, on "Turn off monitor" option, increase the time or select "Never" from drop-down list to set your monitor to always on.
If you are not using XP, settings are the same for most Windows OS, just different ways to access display properties. So if you manage to open display properties, you can navigate to power options and change your power settings.
Aug 19, 2010 | AOC Computers & Internet
The screen on my monitor is too large to be seen. How can I change it?
For best picture, you need to set your PC video resolution to 1280x1024, 60Hz
Right click on desk top to bring up the display properties, select Setting tab to set the resolution, make sure you do have correct video card driver installed in your PC otherwise you may not be able to set the resolution you want.
http://s807.photobucket.com/home/budm/allalbums
May 02, 2010 | Dell E176FP 17" LCD Monitor
The text is too tall and not wide enough. How do i adjust the monitor?
If you are using Xp right click on a blank spot on the desk top select properties,in the display properties you will see settings.There is a option to adjust the screen size,move the bar to the left will increase the size.Under vVsta you will right click on a blank spot on your desktop select personalize,select display settings there you can adjust the bar to the left to adjust your display.Remember to apply the changes before you exit.
Good luck
Sep 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
HOW DO I GET THIS STUPID PADLOCK THAT KEEPS OPENING AND CLOSING IN THE MIDDLE OF THE DELL MONITOR SCREEN TO GO AWAY FOR GOOD?????
Solution Steps For Computers Running Windows XP
1. Click on "Start" at the bottom left of the screen.
2. Choose "Settings"
3. Choose "Control Panel"
4. Double click on the "Display" menu option.
5. Click on the "Settings" tab on the display dialog box.
6. Move the resolution slider to a different screen size (e.g. 800x600, 1024x768).
7. Hit the "Apply" button and select "Yes" that you want to use these new settings.
8. Change the resolution back to your preferred setting. Hit "Apply" and "Yes" again.
9. You can also righ-click on a blank spot on the desktop and choose "properties" to get to the same screen in Control Panel and change the settings
Apr 15, 2009 | Dell E176FP 17" LCD Monitor
Stuck in default monitor setting
After installing XP you have to install all the device drivers. Click here to download Device Drivers.
Thanks, PREM
Mar 29, 2009 | Dell Dimension 2350 PC Desktop
Please reinstall the videocard+ the drivers..
Mar 29, 2009 | Dell Computers & Internet
Problem in Auto adjust mode
Auto Adjust work on the basis of resolution to which Windows set. It occurs mostly if Video drivers are not installed. Please check and install video drivers and also try to change screen resolutions from display properties in control panel.....
Nov 06, 2008 | Dell E176FP 17" LCD Monitor
Monitor nor driver acknowledged
If you just want to adjust the display settings so that they are more to your liking go to Control Panel and open Display. When the Display Properties box opens click on the settings tab. Use the slider bar in Screen Resolution to adjust to 1024x768 or whatever resolution your monitor displays best at. To the right use the pull down arrow to select the highest color quality you can select. Then click on the Advanced button on the bottom left and you should see a Monitor tab. Click on that and ensure your refresh rate is 60 Hertz. Save your settings, accept the change confirmation when it appears and your monitor should be good to go. I have about 90 Dell LCDs and the default Windows drivers for the LCDs usually work great.
Jan 01, 2007 | Dell E153FP 15" LCD Monitor
Dell E176FP 17" LCD Monitor Logo
232 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
