Question about Concept (CC752L) Car Audio Amplifier
Turn on pop
I used the rca outs on a concept 752 amp to hook up a s*** (I mean sony) amp (4 ch) and ever since ive had turn on pops, more so if the high pass filter is off.
Prob with a resistor?
I did tap into my cars power through the fuse blocks
  • 37 Answers
Try to reground the amp
Posted on Dec 06, 2008
I have speakers that have 60wattsrms@4ohms if i hook them up to this amp (xm-zr704)will i blow them?
Surlely you can connect these speaker to this amp . Your amp will deliver 150w at 4 ohms if you use 4 speaker setup. So keep in mind that, don't go for a high volume level. If you need higih volume level go for a speaker which will handle 150 w.
Mar 08, 2011 | Sony Xm-zr704 Car Amplifier Amp 4/3/2 Ch...
I have a 1200 w sony xplod amp, with 2 caps, hooked to my sony xplod 1200 w 15s, I just need to know what size inline fuse I need to have connected to my power wire to my battery? I have a 40A that keeps...
with no signal input the fuse should not blow ,if it blows then the amp has a short on it ,if it blows when the volume is turned up really high the try 60 amps .
Jun 18, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
PYLE PT2001X 3300 Watt Professional DJ Power.just had question about running this amp in bridged mode 4 ohms, here's some amp info 3300 watts total power bridged in 1 ch only.1650 each ch in stereo mode...
In bridge mode the minimum load will be 8 Ohm.
If you are using 4 Ohm speakers, it will mean you will give each side of the amplifier a 2 Ohm load.
Thats to much for this model.
Kind regards,
May 13, 2010 | Pyle PT-2000 Amplifier
Ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Mar 19, 2010 | Hifonics Zeus Z700 Car Audio Amplifier
Were do i plug in the RCA cables from the amp to a factory radio? do i need any sort of adapters if my stereo dose not have inn or outputs? and where do i hook up the remote from the amp?
Most factory radios do not have RCA outs, but most will have a remote wire. Usually used for a power antenna option. Your remote wire from the amp could be hooked to the power antenna wire on the factory radio and it would work great for turning on the amp. As for the RCA inputs on your amp, you will not be able to use them without RCA outs on your factory deck. Although most amps offer a high level input alternative and will use the standard speaker level out on your factory deck. This means the rear channel speaker wires from your factory deck will be used to feed the signal to the amp. You will have to check the instructions and manufactorer recomendations for the amp you are trying to hook up. Have fun and good luck!
Mar 09, 2010 | Stingpro ST444 1850 Watts Complete...
I hooked this 1000 watt amp turns on but it
Your amp needs to be serviced. Bad protection circuit. Take it to a local car audio shop and have them bench test it first to be sure. Hope this helps.
Sep 26, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Just bass through speakers attatched to amp
there is probably a switch that says lpf-full-hpf those are your low pass filter(only low tones) full which is all ranges of sound and high pass filter which when you want to hook up a set of mids or highs I hope that this helps u out
Apr 01, 2009 | Car Audio & Video
Sony xplod xm-554zr amp
if you are trying to run some highs with built in high-pass crossovers off of a amp that is setup for subs(amp is on low-pass) then your highs will not work. You are better off running another amp or running them off of your deck...
Aug 18, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Red light 2
Probably not, as i said there are no user serviceable parts inside this unit. If the units worth it to ya take it in to be estimated. Good Luck
Jun 13, 2006 | Sony Xplod XM-554ZR Car Audio Amplifier
Concept (CC752L) Car Audio Amplifier Logo
115 people viewed this question
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
