Question about Fuji FinePix A345 Digital Camera
A345 No Image
The LCD screen on the camera does not show an image when taking a picture, it remains black with the centering points and other info showing. Older pictures can be retrieved but no new pictures can be taken.
    President:
  • 2,961 Answers
Sounds like something as simple as a full memory card or a lens cover fault, apologies if i'm wrong
Posted on Dec 13, 2006
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
Cannot take a pic. No image in the LCD while pointing at an object or person.The LCD remains gray/black. Even if I snap a pic, no image.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 18, 2010 | Canon PowerShot SX100 IS Digital Camera
My screen on the camera is white how do i fix it?
Hi there its repairable. But your question not so clear. If the image come proper but the LCD screen is white then the problem occur in LCD screen. So just replaced the screen. But after click the snap if that's white or dark ( no image ) then your lens connection or lens only damaged. So please let me know the image is came or not. Both are repairable. Thanks & waiting for your feedback.
Apr 01, 2010 | Fuji FinePix A345 Digital Camera
Not capturing pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 12, 2010 | Canon PowerShot A530 Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
Camera shows no image through the viewfinder or on the lcd screen.pressing shutter button will actuate the camera, but only image is of a black box.using the display button to turn off the lcd does not...
Dec 18, 2009 | Canon PowerShot S3 IS Digital Camera
No image in lcd viewfinder
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
May 25, 2008 | Canon PowerShot A95 Digital Camera
LCD SCREEN PROBLEM
hmmm... that may be a problem within the lcd itself. have you tried seeing the pics that you took an look at it on your computer?
msg me if theres anything else....
Mar 11, 2008 | Fuji FinePix A345 Digital Camera
LCD SCREEN
LCD = Lousy Camera Device? Get used to using the optical viewfinder. The LCD is great for reviewing images after you've taken them, but it leaves a lot to be desired as a viewfinder. Keeping your camera steady is no small feat at the best of times, but being forced to hold the camera away from your body to view an image through the LCD adds a new level of instability to the picture-taking process.
Fuji FinePix A345 Digital Camera Logo
79 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
