If you are referring to a corrupted usb drive
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
It is a trekstore 320 gb.
It still asks for formatting.
try restoring it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
if it still asks to be formatted run the chkdsk utility again and restore it to its defaults you might have to do it a few times for it to get the idea
