Question about Microwave Ovens
Ge spacer xl1800
Makes a large noise when the microwave is running, if i have it on defrost the noise stops...is there anything to worry about
  • surfinsanj Nov 21, 2008
    i took the front cover off and when i turned it on i saw a blue light in the back and some sparking....i assume the microwave was on it last leg
  • William Miller
    William Miller May 11, 2010
    Can you describe the noise or post a video with sound?
    I would suspect the magnetron is failing, especially since you say it doesn't happen on defrost.
    At high (default) cooking power, the magnetron is on steadily. On defrost, the magnetron is not turned on as long.
  • Microwave Ovens Master
  • 9,098 Answers
It may be an arcing high voltage transformer or high voltage rectifier diode or possibly a bad magnetron.
Here are some links you or someone you know can use for test help, but read the safety warnings first:
http://www.microtechfactoryservice.com/diode.htmlhttp://www.microtechfactoryservice.com/xformer.html
http://www.microtechfactoryservice.com/mag_test.html
(continuity can be good even though it is bad!)
We\'re happy to help you with free advice and we\'d appreciate your thoughtful rating of our answer.
Posted on Nov 21, 2008
I have a GE Spacemaker XL1800, about six years old. It heats food fine, but there is a terrible grinding sound while it does so, for the entire time it is running. This has been going on for several...
Personally, I would replace the Microwave. It is bound to be below specification by now if it has been used quite a bit.
Then you will know you will be fine for a few years.
Dec 15, 2010 | GE XL1800 1100 Watts Microwave Oven
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker xl1800 - Funny noise, flickering light
very possible your magnatron is faulty. Disconnect 2 transformer wires and make sure they dont short. try the program again. if no noise, replace magnatron:capacitor and HV diode Please i strongly suggest an electrician help you as it is truely dangerous in there. .
Sep 15, 2009 | Microwave Ovens
Ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1800 quit heating
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Aug 27, 2008 | GE XL1800 1100 Watts Microwave Oven
No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave runs and has functional control panel, but no heat.
The controler board, or the power supply for the magnetron has probably failed, or a safety switch is not working properly. It is also possible that the controler board is in a protect mode because of a defect.
The magnetron uses very high voltage at very high current. There is a very large capacitor in the power supply for filtering the DC for the magnetron. This area of the microwave oven is very dangerous to work on. The power supply can be lethal if proper procedure is not complied to when working on it.
I strongly suggest that you do NOT attempt to service this yourself, unless you have the proper training, test instruments, tools, and service manuals to work on it.
After servicing, the tech is supposed to verify the operating power level, and do an EM (ElectroMagnetic) radiation leakage test. This is important after servicing this type of appliance.
Take the microwave oven in for an estimate. From this you can make an intelligent decision if you are going to have it serviced or replace it.
Excellent article about microwave ovens:
http://www.betterhealth.vic.gov.au/bhcv2/bhcarticles.nsf/pages/Microwave_ovens_safety_issues?Open
Microwave Oven FAQ from GE:
http://www.geappliances.ca/faq/faq5.jsp
Jerry G.
Apr 14, 2008 | GE Spacemaker Over-the-Range Microwave
GE Profile turned off as soon as it start
If you can program it and the problem occures when you push START. Then the problem is a door switch, or the control panel not having a completed circuit. Think of your control panel as an off-on switch.COOK, the control panel switches on for 100% of the time programed. DEFROST,The control panel turns the Cook-Relay on for 30% and off for 70%, on, off, on, off,for the time you programmed for DEFROST. This is how it works. There is no lowering of the output. The output is 100% anything other than COOk is done in % of time on, % of time off. This is why you can hear a "Bump" when Defrosting. The "Bump" is the Cook-Relay sending power to the High Voltage Side, 30% on, 70% off.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool microwave combo - has not power - model RM286PXV2
check the control unit and highvoltagae areaand megnetron , related circuit..
Sep 10, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
