My Mitsubishi VS-50705 had some issues. I created a problem under the VS-40605. But Proton1000 gave me the fix right on by replacing some capacitors around the PIP part of the signal board that connects to the main board. I have the service manual and attempted to adjust using the service menu data the main picture/feed. But I can't get the color to come out correct. The red seems overpowering. The white is like being under a black light. It is overpowering. When the picture starts to fade out in a program to go to another frame the white and colors look better right before the frame changes. Again the PIP picture looks great. Now this set has the split screen. But it won't allow the same feed so the subfeed is black. I switch to the main with 3 little subfeeds scanning channels and they look great. I switch to the main with an adjustable size PIP subfeed and it looks great. I enter service menu adjustment and when I get to the VCJ sub function that brings up the split PIP screen then the subfeed seems fine. Do you think there is still other capacitors in the area I already serviced could still be bad. Or do I need to look into the PIP circuitry to see if the path of the IC is bad? Also any help on focus adjustment would be nice. I don't have a monochrome input so a lot of the service manual adjustments I can't do at this point. PLEASE NOTE THIS IS THE VZ7+ CHASSIS AND THE PIP IS NOT A LITTLE RIDE ON BOARD LIKE OTHER MODELS. IT IS AN IC ON THE SIGNAL BOARD. SO THE ADVISE TO PUT ELIMINATE THE BOARD WON'T WORK HERE.
