Overheat light came on, how long must it rest?
Does this mean it is no longer workable?
  • Anonymous Jan 10, 2009
    overheat light on and will not go off?
Time took care of the problem. It is working just fine.
Posted on Nov 20, 2008
Lenove z560 freezes when at rest
I think that it could be video card overheat try to remove dust from the vga cooler and system fan or upgrade it
but if you can give more information about what you mean by "freeze?
if it's the screen and all fan still turn it's probably an overheat
Oct 27, 2012 | Lenovo IdeaPad Z560 Laptop Computer -...
Xbox frozen due to overheat
just turn it off for the mean time, put in in front of your electric fan or A/C, other even put it inside the fridge, but just letting it have rest for at least 1-2 hours it should be okay,.
Dec 28, 2011 | Microsoft Xbox 360 Console
Error message e4 54040990
It may mean that the disk is no longer usable due to scratches or other over-use reasons. If a new disk, it may mean you're using the wrong brand. This machine works on recommended brands, and the brand of DVD+RW that has proven to be workable on this device, and that I use with no problems, is VERBATIM. Hope this helps you solve what's wrong.
Mar 22, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Red light
Yes this is the YLOD the (Yellow light of death) it happens when the GPU and the CPU overheat and you will need to fix this by stopping the heat build up, you can sned it in and they will fix it for you for $130.
Or you can fix it yourself using a good PS3 Repair guide in under an hour!
Jan 31, 2010 | Sony Playstation 3 (PS3) Console
Service air bag light is displayed on the dic
A service air bag light means that the bag may not deploy in case of an accident so you need to take it back to the dealer and have it repaired. Check your warranty, air bags and seat belts sometimes have a longer warranty than the rest of the car.
Jul 24, 2009 | GMC Yukon Denali Cars & Trucks
Flashy light problem
I do not own a ps3 but that is the most common way of telling you that it has overheated. It will probally work fine after a few hours. Sometimes if it overheats too much it will no longer work no matter how long you let it rest. If it does work then it was just the sensors telling you that it is too hot. If it does not work after then a solder melted, or broke, and the best thing to do is ether get it fixed by a pro,recomended, try doing it yourself,not recomended, or if you got it at a store that will return it and give you a new one then that is the way to go.
Jul 10, 2009 | Sony Playstation 3 (PS3) Console
When the console is turned on there is a red blinking light around the power button
How many red lights?
If it's a full circle, then that means it is the dreaded red ring of death. This means that your console's hardware has had a fatal error and will not work. If your still under warranty, contact Microsoft and they will fix it for you.
For future information, this red ring of death is a very common problem with the 360. This is why; Microsoft made a mistake in the design and basically surrounded the entire internal organs of the systems with an aluminum shell, making overheating a real issue. When your system overheats, the sauter (SP?) holding your CPU (The Central Processing Unit, the thing that basically tells your system what to do) has softens, and your CPU begins to rise. Sometimes this will cause a single red light, which means an overheat. When this happens enough, or if the system gets hot enough, then the CPU will actually lift itself from the connection almost completely, meaning that the CPU is no longer connected. There is no way to fix this without Voiding your warranty, so you have to contact microsoft for them to fix/replace the system.
Dec 27, 2008 | Microsoft Xbox 360 Console
301 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
