Question about Frigidaire FEF336BC Electric Kitchen Range
Code F 91
Last week I used the broiler and when I was done went to clean oven, then a code F91 and a code F9 and F3 come up. Last night I tried to clean the oven again this time it cleaned but when it was done a code F91 came up can you help me with this.
  • hambog27 Feb 02, 2009
    We have not used our oven for quite some time now and then the F19 code appears. I had the control panel replaced before during the warranty and it fixed the problem. It tend to melt the plastic panel, I don't know what's happening in it. Maybe it is just poor design, plastic and heat don't get along very well. Mine was a Kenmore by the way.
  • 370 Answers
This means the maximum oven door lock time was exceeded. Take the back off the oven and check the ohms on the lock motor coil. if no ohms replace the lock motor assembly.
Posted on Nov 21, 2008
I'm trying to clean my self cleaning I am getting an F91 code? Can you help
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%$%$%
Jul 01, 2010 | Kenmore 46123 Stainless Steel Electric...
I get a code f90 when trying to either lock the oven door or attempting to clean the oven
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Jun 26, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
F90 code on Fridgidaire range/oven
unplug the range.
wait 1 minute.
wait 2 minutes.
Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
F2 and F3 Errors just started on my GE Electric Range
I had to clean the contacts in the control panel to fix my same problem.
Nov 10, 2009 | GE Kitchen Ranges
Oven will not turn on
Hi mcifaretto,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Oct 08, 2009 | Tappan TGF320 Gas Kitchen Range
Beeps - won't stop - f90 code - thinks door is locked.
unplug the range.
wait 1 minute.
wait 2 minutes.
May 23, 2009 | Frigidaire FGS365EC Stainless Steel Gas...
Self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
F93 fault code
unplug the range.
wait 1 minute.
wait 2 minutes.
Oct 04, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Kenmore model# 790 94463700 serial# VF 735 37589
unplug the range.
wait 1 minute.
wait 2 minutes.
Aug 23, 2008 | Kenmore 96212 / 96214 / 96219 Electric...
F3 error code
f3 is the code to replace your oven sensor most you replace by pulling the back panel and removing the scerws
Feb 17, 2008 | Maytag MGR5750 Gas Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
385 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
