Question about Jensen Audio Players & Recorders
Connector8 pin from Jensen 1510 to I-Pod
I'm trying to find a 10' connector that goes from an 8 pin to either an I-Pod bottom plug or to a female USB.I'm trying to hook up my Mini I-Pod to the I-Pod plug on my Jensen JDH1510.There's an 8 pin I-Pod plug comming out of the back of the radio marked I-Pod and I understand if plugged into this it will charge I-Pod while in use.Thanks for your help,Kim
mastersaintx
  • 928 Answers
SOURCE: Front Panel Connector: JFP1 hookup
You can go to the link below and see the directions for that. Turn to page 2-17
http://www.premioinc.com/pc/manuals/mb/m266/m266.pdf
Posted on Sep 21, 2008
  • 3 Answers
SOURCE: Bose Sounddock Power connection Schematic
http://www.redflagdeals.com/forums/showthread.php?p=7639870#post7639870
Posted on Nov 09, 2008
  • 26 Answers
SOURCE: Radio Aux feature and not plug connection
http://www.installer.com/cars/by_car.php?carid=6330
Posted on Feb 28, 2009
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
frankzjm
  • 191 Answers
SOURCE: Sony Vaio VGN 'B series' - broken headphone jack.
Hi there, your question has two way you can fix it:
1) see speaker jack circiut on your motherboard, picture here
there are 5 pins to the jack socket, you may just find out 2 and 3 pin which is stereo audio output lines, and also need a ground 5 pin. then connect 3 wires go outside speaker. this way quite tough for you.
if you cannt do this way go next
2) find a USB audio card instead of onboard one. this is very easy.
reference here:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=usb+audio+card&_sacat=See-All-Categories
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 24, 2009
Pinout for 8pin din plug
Hi looking at female 8 pin din with the groove at bottom this is No 8 going clockwise to the left is pin 6 next is No 1 then 4 - 2 - 5 - 3 - 7. ..Hope this helps..
Jan 27, 2016 | JVC Audio Players & Recorders
970A-G46 AM3+ ATX AMD Motherboard
You're trying to use a proprietary part on a different computer.
The plug connector you have was made for a 8(?) contact pin plug connector. (Usually 1 pin is missing, for a 'Key' pin)
The Front Panel header on the mobo you're trying to use it on, has a 10-pin Front Panel header. (Again, 1 pin missing for a Key pin)
You need to separate those individual connectors.
Yeah, I know.
This involves trying to slice/saw them out, and there's Nothing dangerous about that! (Sarcasm)
Moving on............
The connectors in that female plug are female metal terminal connectors. Individual connectors. Example,
http://www.mcmelectronics.com/product/28-9420&utm_medium=Affiliate&ref=cj&utm_campaign=CommissionJunction&utm_source=CommissionJunction
The opening in the front, of course goes over the contact pin, in the Front Panel header on the motherboard.
The back of the connector, shown at the top; is crimped around the insulation of the wire.
The barrel shaped connector slides down into the individual socket hole, in the plug connector.
Looking at the Molex connector, observe the two 'Tangs' that stick out on either side. -> /
When the Molex connector is inserted into the plug connector's socket hole, the Tangs press against the sides of the connector.
When the Molex connector is at the correct depth, in the plug connector socket hole, the Tangs 'pop' out.
They pop out in small depressions, in the sides of the socket hole.
See how they angle towards the back?
If you slide the correct diameter of needle, down in the Front of the plug connector, (And in socket hole), you can depress one tang at a time.
Slides into the socket hole, right next to the Molex connector, and pushes down on the Tang.
Once depressed by the needle, lift up on THAT side a little.
Keeps the tang in a correct position.
Then insert the needle on the other side, and depress that Tang.
You can now remove wire and connector.
Takes a little practice on the first one. Second one goes a little faster, then you're on your way. Just sounds difficult explained so detailed.
With the individual wires, and their connectors; you can plug each wire in where you want. Connect to the contact pin in the Front Panel header, that you wish.
Trying to cut that connector apart, and leave individual amounts of plug for insulation; may prove unfruitful.
Most of the time the material in-between two of those Molex connectors, is very thin.
Maybe one connector will come away with enough material, maybe not. Most will not.
Also you risk slicing your fingers.
Or you could find a plug connector that fits that group of 7-pins, and transpose the wires over to it.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires connect to, is the Front Panel header.
Main wires being;
Power On switch wires
Power On LED light wires
HarDDrive activity LED light wires
Reset switch wires, IF used
Since you have the manual, out of curiosity are pins 2 and 4 Power On LED?
1 and 3 are HarDDrive activity LED?
5 and 7 are Reset switch?
For additional questions please post back in Comment.
Regards,
joecoolvette
Feb 23, 2013 | MSI Computers & Internet
MX46-633V CONNECTING FRONT USB
I believe you're referring to the AOpen MX46-533V
The Front Panel USB header is Blue in color, and located in-between the white No.3 PCI expansion slot, and bottom edge of the motherboard;
http://www.ebay.com/itm/AOpen-Model-MX46-533V-Socket-478-Desktop-System-Motherboard-/130774572519?pt=Motherboards&hash=item1e72c59de7
With the motherboard in the installed position;
5 pins across the Top row, 4 pins across the Bottom row.
Pins across the Top row are numbered EVEN
Pins across the Bottom row are numbered ODD
Starting on the Left side coming across to the Right, Top row;
Pins 2, 4, 6, 8, and 10
Bottom row;
Pins 1, 3, 5, and 7
There are TWO USB connectors supported off of this USB front panel header.
For one of the USB front panel connectors;
A) Pin 1 is USB PWR 0
Goes to the VCC contact pin on the USB connector.
B) Pin 3 is USB_FP_P0-
Goes to the D- pin on the USB connector.
(Data - )
C) Pin 5 is USB_FP_P0+
Goes to the D+ pin on the USB connector
(Data +)
D) Pin 7 is Ground (GND)
Goes to the Ground (GND) pin on the USB connector
E) No pin 9
F) Pin 2 is USB PWR 0
For the other Front Panel USB connector;
A) Pin 2 is USB PWR 0
Goes to the VCC pin on the USB connector
B) Pin 4 is USB_FP_P1-
C) Pin 6 is USB FP P1+
D) Pin 8 is GND
E) Pin 8 is USB_FP_OC0
Leave unconnected
This is more information on a standard USB connector pinout,
http://en.wikipedia.org/wiki/USB
( A USB connector, and a USB plug are not wired the same.
The plug is wired backwards from what a connector is.
Otherwise you would have power and signal going to the wrong pins, and burn the USB Front Panel header out on the motherboard )
AOpen MX46-533V motherboard manual, but it is in Japanese.
May be one in English out there.
The Front Panel header pinout, USB header pinout, etc, is easily cross identified,
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Manual / Japanese manual for MX46533V / Japanese / 1/28/2006
Go to the far right, and click on the Floppy Drive icon above -
3701.1 KB
On the next page click on the mirror server website that is closest to your country.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country server name it may take up to 30 seconds, before the first page comes up.
(File is downloading in background)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 19, 2012 | ASUS P5PE-VM Motherboard
I have an old acer monitor model 7134T, the problem is its 15-pin connector (that plugs into cpu) is broken and i want to repair it. Can anyone tell which color wire goes to which pin #?
A female DE15 socket (videocard side). Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 ID2/RES formerly Monitor ID bit 2, reserved since E-DDC Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 KEY/PWR formerly key, now +5V DC Pin 10 GND Ground (VSync, DDC) Pin 11 ID0/RES formerly Monitor ID bit 0, reserved since E-DDC Pin 12 ID1/SDA formerly Monitor ID bit 1, I²Cdata since DDC2 Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 ID3/SCL formerly Monitor ID bit 3, I²Cclock since DDC2
Feb 16, 2010 | Acer Computers & Internet
I have a computer monitor that i dont know where the power plug goes
that will be the back side . in the bottom ...There you will find three pin male connector...Your power cable will have three pin female connector..You can plugged in and check....hope you will succeed...
Nov 26, 2009 | Computers & Internet
Charging socket
You have to do this correctly or there's going to be a lot of smoke! The black wire is negative, the white positive and the green is ground. The 3-pin female XLR connector you refer to has the three pins where the charger plugs in. Position this connector to that when you look at it, the three pins form a V. The top two pins are directly across from each other, and the bottom pin is at the bottom of the V. The black wire goes to the top left pin, the white goes to the right top pin, and the green goes to the bottom of the V.
Nov 10, 2009 | Shoprider Sprinter 889B-4 Scooter by
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
Jensen XA2150 Hi Input help
According to crutchfield, this connector should have come with the amp. Was this an open box? I would suggest getting a replacement molex connector from jensen. I see what you are talking about in the manual, and if you don't have the supplied connector, you have a big chance of frying your amp. The manual expects you to have this connector, and is not specific about the actual pins. For all you know, you could be wiring it the opposite way. Either that of call jensen, and ask how the pins are layed out. If you are confident you do have it wired properly, you could try both pins, and see which is the ground, but this is risky of course. There is also the chance there is no actual metal connector in one hole. You can also test for impedance if you have a multimeter, and you definitely should if you are taking shot in the dark with your amp.
Nov 19, 2008 | Jensen XA2150 Car Audio Amplifier
Looking for a control pod.
I recently had a similar problem. In my case the left speaker had no sound. Finally traced the problem to a broken wire inside the control pod plug, which I destroyed by dissecting it. For those who have the experience, or know someone who does, purchase a new plug, which a Mini DIN 8 pin (RS-422 standard). It should be available at any good electronic parts store. Solder new plug on to cable, which requires a fine electronic soldering iron and a fair bit of skill (the wires are very fine).
Look at the plug (from the rear); you will see it comprises a top row of 3 pins equaly spaced; a middle row of 3 pins (there is room for 4 pins but one pin is missing just left of centre); a bottom row of 2 pins. I numbered these as follows:
8 o 7 o 6 o
5 o 4 o 3 o
2 o 1 o
The wire from the controller comprises 8 coloured cores and a bare core. The wiring of the eight cores are as follows:
DIN CORE PCB
pin 8 - brown 8
pin 7 - red 7
pin 6 - orange 6
pin 5 - yellow 5
pin 4 - green 4
pin 3 - blue 3
pin 2 - white 2
pin 1 - black 9
body clamp - bare wire - G
In case your coloured cores vary from mine I have also listed the pin each one goes to on the printed circuit board plug, which will let you identify the colours.
Oct 11, 2007 | Level 9 Sound Designs Monsoon Planar Media...
Open Questions:
23 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
