Question about Panasonic Panafax UF-560 Plain Paper Laser Fax
How to save fax numbers
We lost our manual and we are trying to enter fax numbers and save them can someone tell us how to do that easily. Thanks so much.
    Genius:
  • 2,120 Answers
Press Function
72
set
1 for ONE TOUCH NUMBERS
set
press 01 on the soft pad
enter fax number with the DIALING NUMBER KEYS
set
enter name with LETTERS on the soft pad
set
continue with 02, 03, 04 etc.
when done press stop.
press Function 67
set
cut out directory sheet on dotted lines and put under the mylar sheet on the soft pad.
press Function 62 set to print out the list of one touch numbers.
Posted on Nov 20, 2008
I have lost instruction manual. How do I 'copy' on a canon FAX-L120
1-Load the document face up in the ADF/Tray
2-Enter the copy mode by pressing Copy Button
3-Enter Quality
4-Press Start
For any further information/ clarification please refer to Chapter 6, Page 80 & 81 for the Canon i-SENSYS FAX-L120 Manual.
Save the Manual for Future reference
Hope it helps! Good Luck!
CreativeTECH
Mar 11, 2011 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
Unable to change names/add addresses in the address book faxing
Try Googling (Kyocera)(KM-3035)(manual) without parens for instructions.
Nov 03, 2017 | Kyocera Mita KM-3035 All-In-One Laser...
How to save numbers
Your machine can store up to 30 numbers. To store numbers, use the following process:
  1. Press functioni button once
  2. Press right arrow > once
  3. Assign a two digit speed dial number or press the right arrow (machine will suggest a 2 digit speed dial number
  4. Enter the fax number (use speaker button if a mistake is made to clear)
  5. Press Start/Memory button
  6. Go to Page 28 in user manual
At this point, there's a chart for entering names for the fax numbers which can be found in the owners manual at this link: http://www.sharpusa.com/files/fax_man_UXP115.pdf
After the name has been entered, press Start/Memory button to Store and press Stop button to leave the process.
Best of luck and hope I helped.
Greg
Jun 16, 2009 | Sharp UX-P115 Plain Paper Thermal transfer...
How to fax forward?
You can set your product to forward incoming faxes to another fax number. When the fax arrives at
your product, it is stored in memory. Then your product dials the fax number you have specified
and sends the fax. If it cannot forward a fax because of an error (for example, the number is busy)
and repeated attempts to redial are unsuccessful, your product will print the fax.
If the product runs out of memory while receiving a fax, it will terminate the incoming fax and only
forward the pages and partial pages already stored in memory.
When using this feature, the product must be the one receiving faxes (not the computer) and the
answer mode must be set to Automatic (see Changing how the product answers incoming faxes).
To use fax forwarding
Press menu/enter.
2 Use the < or > button to select Fax Setup and press menu/enter.
3 Use the < or > button to select Fax Recv. Setup and press menu/enter.
4 Use the < or > button to select Forward Fax and press menu/enter.
5 Press > to select On or Off and press menu/enter.
6 If you choose to turn fax forwarding on, use the alphanumeric buttons to enter the fax number
where you want the fax to go, and press menu/enter to save your selection.
Apr 15, 2009 | HP LaserJet 3330 All-In-One Printer
How do I program in a fax number?
Register Fax dstinations:
  • Press User tools/counter button
  • Select System settings using the up and down arrows then press Ok
  • Select Key Operator Tools using arrows then press Ok
  • Select Address book Management using arrows then press Ok
  • Select Program/change using arrows then press Ok
  • Enter the registration number or Quick dial key, then OK
  • Enter user (destination) name using Quick dial keys - OK
  • Press Dest.
  • Press Fax settings using arrows then OK
  • Enter the fax number then press OK
The "Programmed" message appears, and then the "Address book" display returns.
Press the User Tools/Counter button.
Good luck and please rate me, thanks.
Sep 08, 2008 | Gestetner DSm618 All-In-One Printer
Manual feed for HP 1115
you can get the manual, by entering a model number through the printer driver link here
Mar 17, 2008 | HP PhotoSmart 1115 InkJet Printer
One Touch Dialing numbers won't permanently save to FAX machine
If you followed the procedure F 7, 2 set, 1 for speed dial, enter your free speed dial space, enter your fax #, set, enter the name, set.(continue to next free speed dial key or stop) If this doesn't work then you may have a bad battery on the main board that saves the data if the power goes off.
Feb 04, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
HELP
We also have losted our manual and need to reset everything but can't rember how to do it.. Can someone please help me out on this problem. Very much appreciated!!
Jan 22, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Saving fax numbers
yes, you may.
If the Fax machine has a Memory function press it.
then type the number then enter.
or read the manual..
or visit www.canon.com
Dec 11, 2007 | Canon FAX-L800 Plain Paper Laser
Panasonic Panafax UF-560 Plain Paper Laser Fax Logo
145 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
