NorStar M7208 Corded Phone
Problem for NorStar M7208 Corded Phone
Handset problem
By cforde on Nov 19, 2008
I have a Norstar M7100 and when I received a call I can hear the caller but the caller can't hear me! cam you help?
Solution #1
posted on Nov 20, 2008
Not Rated)
LuckyLindy1
Rank: Apprentice
Rating: 0%, 0 votes
It sounds like you have a defective handset cord or handset. First, at your phone, switch your handset with another phones handset that you know for sure works. From your phone make a test call. If the caller can now hear you, the original handset from your phone is defective. If the caller still can not hear you, switch your handset cord with another handset cord from another phone that you know works. From your phone make another test call. If the caller can hear you, then your original handset cord is defective. You can purchase another handset cord from your local office supply store. Your phone uses a standard handset cord. It may be difficult to match the original color of your handset cord. Be sure to take your defective handset cord with you, so you can try to match the color. If the caller still does not hear you. Put your original handset and original handset cord back on your phone. Then plug your phone in to another wall jack, that you know works with another phone. The other phone needs to be an identical phone to yours (same number of buttons and same model number. The model number can be found under the phone). Wait approximately 90 seconds, sometimes longer, after you plug your phone into the other wall jack. Now, make another test call from your phone. If the caller can now hear you from your phone with it plugged into another working jack, then you have a defective station port or jack where your phone was originally plugged in at. If the caller still can not hear then you have a defective phone.
Was this helpful?
Yes
No
Popular Solutions for NorStar M7208 Corded Phone
Questions and Unsolved Problems for NorStar M7208 Corded Phone
Do you recommend NorStar M7208 Corded Phone?
Answer
Answer
How do I check messages from outside the office
Answer
Anybody know the function code so that an extension cannot make outgoing calls?
Answer
How do I verify that another extension does not indicate messages on my phone?
Answer
Where do I go to change the name on the display button so that when I call someone within the... (More)
Answer
I changed the user on a phone and when I call to leave message, the right name shows up, but when... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For NorStar M7208 Corded Phone:
Top Phone Experts
Rank: Guru Guru
Solutions: 567
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Phone Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
NorStar
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
