Sharp Z-70 copier - print outs are mostly black?
Copier appears to work fine, except the print out come out mostly black - I have replaced the toner to no avail
Check the dum cleaning blade. Usually the blade becomes weak and does not clean the drum properly. You can either replace just the drum blade or replace the entire drum cartridge.
If the copies are coming out solid black, then either the exposure lamp or the thermal fuse for the exposure lamp is/are burned out.
Posted on Nov 20, 2008
Mx2300 write code f2-70 after replacing the black cartridge
F2-70 is indicating an improper toner cartridge K.
If you have just changed the black toner cartridge & the error appeared then the new toner is at fault.
Replace the toner cartridge with another cartridge, turn the machine off & back on & the machine should reset.
Hope this helps.
Jan 09, 2017 | Sharp Mx-2300n Copier Color Mx2300n...
Most Copier Cartridge have chips on them that tell the copier I am new, Replacing the toner/refill, does not change the chip info as long as the chip says I am empty its empty to the copier, replace the cartridge with a new OEM cartridge.
Mar 17, 2015 | Sharp FO-2081 Copier
Why is my Sharp MX-M263N copier creating black lines on documents?
Check out my video for helping this issue. I'm not sure if it pertains to your model, but it may be of use to you.
How To Remove Lines from copies prints on Sharp copier
Jul 30, 2014 | Sharp MX-M623N Black Toner Cartridge...
Our Sharp mx-3501n copier flashing improper cartridge code: f2-70 and will neither copy nor print. If we restart the code still remains never go out, Do you know what is the problem? Thanks. my...
Your copier is not accepting your black toner cartridge (F2-71 Cyan, F2-72 Magenta, F2-73 Yellow). It either is not inserted properly, the packing tab is not removed from the back, or a faulty cartridge. Often 3rd party cartridges that the manunfacturer "guarantees" will work will bring this code. In short, the copier is rejecting your black toner cartridge and you should replace it.
Oct 25, 2010 | Sharp MX-3501N All-In-One Printer
I have a sharp ar-m257 copier. my copies were
There are a few thing's > have you cleaned the optic's > clean the primary charge unit in the drum unit > how old is the drum & developer? Also, is the copier calling for for "Maint's Req"
Apr 05, 2010 | Sharp AR-M257 Black and White Copier
My Samsung CLP-300 also does this.
Please. change the proptrty of printers utilits
Sep 08, 2009 | Sharp AL-1000 Copier
How do I get to the black toner reading on a Sharp AR-M257 copier
Hold down the Copy button and you should see a readout for the total copies printed from the copier and the percentage of toner left in the unit.
Aug 28, 2009 | Sharp AL 800 Copier
No error message but copier light doesn't come or number of copies doesn't work
let it run eventually the toner lite will come on, sharp copiers will run an extended period trying to add toner to the developer. developer is 70% iron filings and 30% toner as it uses the toner it cycles more in to stay at the proper level.
Apr 14, 2009 | Office Equipment & Supplies
Stopped working
try to see if there is a number appearing after u, maybe its u2-40 which is a toner problem since you run it continously. You can check it by pressing the copy button(green) and the sub code will appear. try to replace the toner cartridge and reset the copier by turning it off and on again, hope it helps
Nov 07, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR BC320 not printing correct colors
sounds a lot like the print heads are clogged. Can you print a test page, and how does that come out?
Feb 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
163 people viewed this question
