Question about HP Photosmart 2610 All-In-One InkJet Printer
Printing problems My HP Photosmart 2610 has suddenly stopped printing. The printer icon comes up when I pressprint but there is no documents pending.
  • lina_kennedy Nov 19, 2008
    No I've tried all that and the problem is still there.
  • comment
    comment May 11, 2010
    Do any of the other functions work? I.E. Scan to PC, or Fax? Are you printing / copy printing from the printer, or sending a job to the printer from a computer?
    Scholar:
  • 78 Answers
  • OK.. Have you checked the printer setup in "Printers" to see if the "Offline" function is checked. If so, click on it again to remove checkmark.
  • If not that, then check the printer port, to make sure it is printing to the proper port..I.E. LPT1 or USB or ???
  • If not that, delete the printer completely, turn the PC off, and let it re-discover the printer, and it should automatically find the drivers, then try again.. It sounds like a corrupt printer driver because of the way it is "Leaking" the print jobs..
Posted on Nov 19, 2008
  • 57 Answers
Hi al of you
this problem sometimes overcome by just restart your PC.
hope this helpful for you,
thanks
Hamedo
I want to wireless print to my HP 2610 printer through an Airport express router using Windows xp. When I attempt to install the driver I get a message that a printer cannot be detected on the network...
First install the Printer with USB connectivity.
Then insert the printer driver CD again. You will get the Add a Device option this time on the Welcome Screen.
Select it. Now before you continue, just add the exceptions to the firewall list.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01545804
Perform the steps given on the above document to add the exceptions to firewall.
Then Make a right click on My Computer Icon on your desktop.
Go to Hardware Tab. Select Device Mananger.
Go to View Tab on Device manager and select Show Hidden Devices.
Then search for Multifunction Adapter. Uninstall the printer icon under it.
Now click on Add a Device.
Try installing now.
May 28, 2010 | HP Photosmart 2610 All-In-One InkJet...
My printer all in one hp photosmart 2610 is
Hai
I request you to check the ink cartridges as the paper is blank it could be due to empty ink cartridges or dried ink cartridges. Here is the weblink to replace ink cartridges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00257147&cc=us&lc=en&dlc=en&product=422000
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00257066&cc=us&lc=en&dlc=en&product=422000
Jan 04, 2010 | HP PSC 2355 All-In-One InkJet Printer
My photosmart 2610 keeps a list of all old jobs.
Actually, the list is not kept by the pc, but by the pc attached to it.
First of all, disconnect the USB cable from the 2610.
Go to Start > Run > type in "services.msc" without the quotes.
It will show a list of services, locate "Print Spooler services" from the list. Stop the service and Start it again.
Go to start > run > printers and faxes > right click on the printer icon and select "cancel all documents"
Connect the USB back. The printer should be turned ON.
Ideally the printer icon should have "0 ready" written under it.
If it does, you are good to go.
Jul 05, 2009 | HP Photosmart 2610 All-In-One InkJet...
My HP 2610 defalt has changed to fax instead of print mode
follow this trouble shooting steps your issue should resolve.
On Computer:
Click on Start >> Control Panel >> Printer and Faxes >>
check which Icon is enabled if Fax is Enabled Just Disable it By right clicking on it and Disable.
Now Right Click on Printer Icon then select " Use Printer Online"
then set it as Default Printer.
Now try to print your issue should resolve..
I hope it helps ...raj 9866486995
Raj....
Feb 17, 2009 | HP Photosmart 2610 All-In-One InkJet...
Printer is pending
the print spooler is not letting it print cancel the pending jobs you will be able to print fine keep on cancelling the documents unless the icon shows 0 document pending ....
Dec 16, 2008 | HP Deskjet D2430 Printer
Printer Connected but wont print
- go to printers folder then check the status of your printer - if it is offline, right click the icon and select use printer online...
- check if there is pending documents becuase printer wont print if there is pending document in queue- to clear the pending docs. right click the icon and select cancel pending document
- printer OJ 5610 icon should be in ready status, no pending documents, and the icon has a checkmark as as default printer...
Nov 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp 5610 won't print
If you need Vista drivers for your printer, go to HP.com to get them and see if that works.
Jun 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Printing suddenly slows down for no apparent reason
This is more likely a computer issue than a printer issue. The only way to prove it is essentially try the printer on another computer. Preferably one with more RAM and faster CPU.
You could try closing some of the running processes via the Task Manager. This would free up some resources and may help the process.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
99 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
