Question about Sony Handycam DCR-IP1 Micro MV Digital Camcorder
DCR- IP1E won't turn on
Hi I would like to find out, the camera was working perfectly until recently when i went to charge it all that came up was the red charging light. I left on charge for an hour and now the camera doesn't turn on. The flap at the front (in front of the lens) doesn't seem to cover the lens. My main concern is with the camera not turning on. It has been charged fully as insructed in the manual however its still not turning on. I am unable to do anything with it. The light flashes but there is nothing on the screen and its doesn't make a noise to notify that its working. please help Thank you
  • handri Jun 10, 2008
    I have exactely the same problem. What can be done????? Nowhere to find a solution??? HELP please.
    Hans
sandrew
  • 2961 Answers
SOURCE: CAN ANYONE HELP SOLVE THIS PROBLEM URGENTLY?
Unless somebody comes up quickly with a better solution for you, it may be an internal battery problem, especially if you keep having to set the time. For your local repairer click on this Sony support page. http://www.sony.co.uk/support/ShowExternalPageForProduct.action?supportProductModelName=DCR-PC105E&targetTab=externalLinkType_manual&site=odw_en_GB&page=ProductSupportDealerLocator§iontype=Support&externalUrl=http%3A%2F%2Fpdf.crse.com%2Fmanuals%2F3081627112.pdf&externalLinkType=manual
Posted on Dec 13, 2006
SOURCE: Sony HC-40E Charging Problem
Try loosening some of the screws on the handycam, to allow you to prise open the case slighly, allowing access to the strip coming from the switch. Cut a thin piece of rubber from an eraser, and gently stroke the wire strip with it. It works!
Posted on Sep 03, 2007
  • 169 Answers
SOURCE: lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Posted on Sep 14, 2007
ripleymojica
  • 643 Answers
SOURCE: Sony DCR-SR290 camcoder- turns off abruptly
ribbon cable located in the rotating lcd is cut. thats why the shut down its grounding it self out. needs to be replaced. real pain though, cable is serpintined around the part that rotates. sony does flat rate for prob. about 250 US
Posted on Jun 02, 2009
  • 125 Answers
SOURCE: My camcorder seems to be functioning normally
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. My child is already 2 and I can't imagine how to be without camcorder. All the best for the baby and Good luck
Meggita
Posted on Sep 28, 2009
Camcorder not working without charger plugged in.
hi if you have the charger plugged in the camera the you have power to work it, if you unplug the charger and it dose not work, the I think the battery is not charged fully or it is no good after being left to long, check to see if the battery is charged. I hope this helps you, please let me know.
Mar 30, 2014 | Sony DCR-DVD602E DVD Camcorder
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Cannot playback tape on Sony DCR HC36
Have you try cleaning tape? Sometimes, it is just a dirty head. Try to clean it, see if it helps.
Jan 06, 2010 | Sony Handycam DCR-HC36 Mini DV Digital...
NTSC recording playback
You can hook it up to a vcr or tv input and play directly from camcorder to television
Jul 02, 2009 | Video Cameras
Battery life?
Here is a replacement source
The batteries are covered under warranty for three years. Sony batteries are know for not keeping a good charge after a few years.
If there not holding a charge, they wouldn't appear on the LCD screen at all. I the AC power is working fine, then that probably isn't the source for not getting a charge.
You could try lightly scraping the contacts on the battery and see if that makes a difference and recharge them.
Jul 18, 2008 | Sony Handycam DCR-TRV6 Mini DV Digital...
AC Power Adapter
Hi here is link where you can buy this ac adapter/charger for DCR-DVD108
http://azsurplus.com/index.php?main_page=product_info&cPath=1_85&products_id=1910
it is also works with more models as mentioned bellow
Compatible Part Numbers: AC-L20A, AC-L25A, AC-L25B, AC-L200
Input: AC 100V-240V 50/60Hz
Output: 8.4V 1.5A
Dimension Approximate: (48mm x 29mm x
To Use With :
CCD-TRV138
CCD-TRV338
DCR-DVD103
DCR-DVD105
DCR-DVD108
DCRDVD202E
DCR-DVD203
DCRDVD203E
DCR-DVD205
DCR-DVD305
DCR-DVD403
DCRDVD403E
DCR-DVD405
DCR-DVD505
DCR-DVD508
DCR-DVD7
DCR-DVD92
DCR-DVD92E
DCR-HC1000
DCR-HC1000E
DCR-HC16E
DCR-HC17E
DCR-HC18E
DCR-HC19E
DCR-HC20
DCR-HC20E
DCR-HC21
DCR-HC22E
DCR-HC26
DCR-HC28
DCR-HC30
DCR-HC30E
DCR-HC32
DCR-HC32E
DCR-HC36
DCR-HC39E
DCR-HC40
DCR-HC40E
DCR-HC42
DCR-HC42E
DCR-HC46
DCR-HC65
DCR-HC85
DCR-HC85E
DCR-HC90
DCR-HC90E
DCR-HC96
DCR-HE20E
DCR-HE22E
DCR-HE30E
DCR-HE32E
DCR-HE40E
DCR-HE65E
DCR-HE85E
DCR-IP1
DCR-IP1E
DCR-IP210E
DCR-IP220
DCR-IP220E
DCR-IP45E
DCR-IP5
DCR-IP55
DCR-IP55E
DCR-IP5E
DCR-IP7BT
DCR-IP7E
DCR-PC1000
DCR-PC106E
DCR-PC107E
DCR-PC108E
DCR-PC109
DCR-PC109E
DCR-PC350
DCR-PC350E
DCR-PC53E
DCR-PC55/B
DCR-PC55/R
DCR-PC55/S
DCR-PC55/W
DCR-PC55E
DCR-SR100
DCR-SR200
DCR-SR300
DCR-SR40
DCR-SR60
DCR-SR80
DCR-SR82
DCR-TRV280
DCR-TRV480
HDR-CX7
HDR-HC3
HDR-HC5
HDR-HC7
HDR-SR7
HDR-UX5
Jul 11, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Operation
if you power the camcorder from the call socket, if it works that mean the battery has bad.
May 12, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Black screen
The LCD screen on my Sony gradually lost the image. It is caused by the flexi/ribbon cable that runs from the camera body to the inside of the LCD screen breaking down. The copper tracks have broken. They may sometimes touch to give you a connection , but it will get worse. A replacement flexi is the only answer.
For my DCR-IP1E it cost me £31 (thats uk money....not dollars)
Sony Part Number A-7111-611-A (FP733 Mount) Taking the old one out was slightly tricky, putting the new one in is very tricky! I work in electronics, so I could achieve it but if you are not happy with electronic stuff, find someone who is.Straight forward for a repair shop expert. Tools needed? Just a small cross head screwdriver. Keep all bits with a note as you go along. Good luck.
Oct 30, 2007 | Sony Handycam DCR-IP1 Micro MV Digital...
Sony DCR-HC40 Battery Charging Problem Hi Mates - I did purchase a Sony DCR-HC40 camcorder around an year back and it was working superb till few days back. As of date, i am facing a problem where...
Had the same thing happen to me. Went out and bought a new battery and it, too, does not charge. Apparently something messed up with the in-camera charging system. It will charge for several minutes (charge light illuminated) and then the charge light goes dark. Battery gage shows that there is virtually no time left on either battery (old or new). Anyone have any ideas other than a trip back to Sony?
Sep 14, 2005 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Handycam DCR-IP1 Micro MV Digital Camcorder Logo
61 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
