HP Color Laserjet 2600n. Magenta color fades on both left and right side of printed page. Cartridge is factory and has 55% remaining.
  • effander Jan 13, 2009
    I happened to find this web page describing exact the same problem as I have. The magenta is weak and is fading on both left and right hand sides.
    I changed to a new cartridge and also tried to find some way to reset the printer to factory defaults. But the problem remains. Anyone with some hint how to fix it???
    Effe Andersson
    Partille, Sweden
    email: effe.andersson@partille.se
This has become a common issue on these machines - due to design two laser-to-drum mirrors in the laser/scanner assembly face upwards. Because the unit is not sealed, the upward facing mirrors are a nice place for toner dust to settle.
The repair is rather easy for a trained professional - in theory anyone with the right set of instructions could perform the procedure, but I'd highly recommend a novice not try.
Instead call a trusted computer repair shop and explain the situation and that you need to have the mirrors in your laser/scanner assembly cleaned to resolve issues with faded color output. A reputable service agency with experience in HP printer repair should have no problem doing this procedure in less than an hour – so they shouldn’t charge you for more than an hour or two of bench labor. If the repair facility you contact doesn’t understand your request or tries to blame your toner cartridge; hang up and call another company.
Posted on Aug 03, 2009
  • 32 Answers
Have you tried a different magenta toner cartridge?
This would be the first thing to try.
Also the magenta laser might be dirty or fogged. The laser is located in behind the slot you see once you remove the toner cartridge.
The laser is protected by a plastic shutter. The shutter release is located on the right side. When you slide the cartridge in the cartridge triggers this release and the shutters opens exposing the laser.
You can take a q-tip, slide it inside the slot and run it left to right. Be careful not to leave any residue or lint in the slot.
Posted on Nov 19, 2008
Color is offset and blurred. There is no problem printing in black. Printing test page shows the same symptoms.
Hello
The color of HP LJ 2600n fades due to following reasons
1. the color cartridge near to empty 2. due to dust on reflection mirrors inside the printer
if the color cartridges are OK, then you need help of HP technician support, because cleaning of mirrors is very technical in nature for 2600n.
Dusty Environments can lead to Laser Scanner Contamination. The dust layer on the mirrors prevents proper transmission of the laser output in the imaging system leading to faded colors on the printed page. The initial stages of this failure typically occur in the magenta or yellow color planes as faded or light color. Often the left side is more faded than the middle.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach easily.
Also, please ensure that the printer is relocated from the current location to a more dust free zone.
Hope this helps, if so do rate the solution
Jan 08, 2011 | HP Color LaserJet 2600n Printer
Our Magenta cartridge is not printing properly. We replaced it with a brand new cartridge and the problem remains the same. It barely prints, if at all, to the left of the page and gradually increases...
It's probably a dirty laser scanner. The magenta is most prone to this type of problem. Here's a link for instructions. http://forums11.itrc.hp.com/service/forums/bizsupport/getattachment.do?attachmentId=297096&ext=.pdf
Dec 14, 2009 | HP Color LaserJet 2600n Printer
Hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
Sep 14, 2009 | HP Color LaserJet 2600n Printer
Magenta cartridge not working despite being full
This happens due to Laser sCANNER Contamination.
Light Output that typically starts fading along the outside edges of the media. The first noticable color would be Magenta.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach eazily.
Aug 27, 2009 | HP Color LaserJet 2600n Printer
PRINT FADING ON RIGHT HAND SIDE WHILE BLACK CARTRIDGE SHOWS FULL.
your cartridge is third party toner insert new hp original cartridge before cleaning
Jun 23, 2009 | HP Color LaserJet 2600n Printer
Page is printed but fade
The toner cartridge is faulty. It is possible that when you pulled out the strip that the whole thing didn't come out. Return the cartridge (with a couple of printed sheets to demonstrate printing) and the receipt and you should get a replacement.
Oct 24, 2008 | HP Color LaserJet 2600n Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
HP 2840 Colour Laserjet Printer Problem
Don't ever use compataable cartridge for printing .
(1)Check for printer sleave damage....
(2) check for any noise from printer when printing noise from fuser section.
(3).. Print a Demo color level page ...
(4)Check for scaner section ......
Thank you.
Feb 04, 2008 | HP Color LaserJet 2600n Printer
Colors are uneven, too much green on the right side and too much red on the left
The internal optics are dirty. It's a known problem that HP's been ignoring.  More info is here:  http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1202453734788+28353475&threadId=1073731
Detailed instructions are on this page - look for Don Thompson's posting at Sep 15, 2007 23:38:51 GMT and click the papercliip to see the procedure. It's not for the faint of heart.
Dec 12, 2007 | HP Color LaserJet 2600n Printer
451 people viewed this question
jasbo
jasbo
