Question about Vtech DECT 6.0 Cordless Phone with Digital Answering System
VTech Digital Cordless phone and Answering machine does not pick
I have setup my announcemnt, date time, # of rings. The first few tries it just rang and rang then finally the machine picked up. But that only happened once and now it's been a few days and the answering machine is not picking up at all. I have turned it on and off. Unplugged it and plugged it back in. Nothing worked. I will be returning the machine by this weekend if it isn't going to work.
SOURCE: When someone calls my phone rings 4 times then
You must turn off your internal answering machine. There should be an on and off button somewhere on the main base.
Posted on Jun 06, 2009
consultel1
  • 860 Answers
SOURCE: dont have a problem I am looking to by a VTech
Yes, there is an on/off for the answering machine portion of the phone. On default it's set to off til you set your settings and record your greeting.
Posted on Dec 15, 2009
SOURCE: HOW DO I SET THE DATE & TIME ON THE ANSWERING MACHINE DS6221-1
Hi there, I found my manual that states:
Press MENU/SELECT to display menu when in idle mode.
Press the up or down triangles to reach DATE/TIME. Press MENU/SELECT.
Use the keypad to set the year. Press MENU/SELECT.
Use the keypad to set the date. Press MENU/SELECT,
Use the keypad to set the time. Press the up or down triangles to select a.m. or p.m. Press MENU/SELECT
The screen displays STORED and you'll hear a confirmation beep.
George Rocks
Posted on Jul 23, 2010
  • 102366 Answers
SOURCE: how do I change the
Since you didn't tell us the model of your machine, go to
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
and enter the model number into the search box.
Posted on Aug 18, 2011
  • 24 Answers
SOURCE: I have a Vtech dect
For this problem contact your mobile service provider.....
Posted on Aug 25, 2011
How to change number of rings on Vtech cordless phone
The 6041 isn't an answering machine. It will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on your answering machine, consult its documentation. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jul 30, 2014 | Vtech Cordless 6041 Phone
Cordless phone base only rings three times till the answering machine picks up
Read your manual on how to choose more rings before your answering machine picks up...usually 7 is the most you can set it for.
Apr 04, 2014 | VTech Communications CS6419-2 - cordless...
How do I change the number of rings before answering machine picks up Vtech cs6619
The CS6619 isn't an answering machine. It will ring until you answer, an answering machine picks up, or the caller hangs up. To change the ring count on an answering machine, please refer to the documentation for that machine. If you require further assistance, please add a comment to this question and identify the answering machine.
Feb 17, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
Set number of rings before answering machine picks up
Enter the model of your VTech DECT 6.0 system into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Feb 08, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I change the number or rings on my vtech cs6619-2
The CS6619-2 isn't an answering machine. It will continue to ring until someone or something picks up, or the caller hangs up.
To change the number of rings before your answering machine picks up, please consult the documentation for your answering machine.
Dec 05, 2012 | Vtech DECT 6.0 Digital Cordless Phone
How do I set the number of rings before the answering machine picks up on a Vtech CS6114 cordless handset?
The CS6114 isn't an answering machine. It won't pick up any calls on its own.
If you have an answering machine attached, refer to the documentation for that machine or else repost your question specifying the make and model of your answering machine.
If you subscribe to an answering service provided by your phone company, contact them for information and help.
Sep 04, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
How to adjust the time duration before the answer machine is triggered on when the incoming call rings? currently only two rings are rang before the answer machine kicks in, which is more than often not...
Since you declined to specify the model of your VTech system, enter it into the search box at
to download the manual.
Aug 07, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
How do you change number of rings before answering machine picks up?
Since you declined to specify the model of your VTech answering machine, enter it into the search box at
to get the manual.
Jun 19, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
I would like to change the number of rings before answering machine picks up. How do I do that? I have a panasonic cordless dect 6.0 phone
I had the same problem but couldn't figure it out either ..... UNTIL, I changed the date and time (which was very old, actually Sept/2007) to the current date, year, time, am/pm, etc.
After I changed the date, time, year, etc. my phone went back to its normal default of 3 or 4 rings & then the answering message plays.
Hope this helps!
Mar 30, 2011 | Panasonic DECT 6.0 Expandable Cordless...
Can't turn off answering machine or change from 2 rings.
Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download the manual.
Jan 02, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Vtech DECT 6.0 Cordless Phone with Digital Answering System Logo
51 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
