Question about Zenith A27A23W 27" TV
TV Philips Magnavox HD1918 C125 19" 1998 problem
Hello friends! I have a TV Philips Magnavox HD1918 C125 19" 1998. The problems is: When I turn it on, the screen goes white, then changes to gray with various scrolling horizontal white lines and one top to botton vertical white line, near the left side. The sound is working fine and I can change the channels. I have changed the TDA3653B CI, but nothing different happened. Does anyone have any idea for repairing my TV? Thanks in advance! Mario Sergio
tvtek
  • 1284 Answers
SOURCE: horizontal lines across the top 2 - 3" of the screen
Sounds like you have some capacitors that are needing to be changed in the vertical circuit. The cost I cannot quote but, it probably won;t be worth the cost as replacement TV's are much cheaper now. Zeniths and other brands for the longest time have used not controls inside the TV, they are technician adjustments through a service menu only.
Posted on Apr 20, 2007
jimbo4026
  • 50 Answers
SOURCE: horizontal line in top screen
could be vertical output IC or capacitors located close around the IC
Posted on Nov 28, 2007
ginko
  • 19396 Answers
SOURCE: No picture, Horizontal line center of screen
Can be a case of vertical collapse. If this is the case, then the vertical oscillator and/or the vertical driver circuit are faulty. .
You can take you problem directly to zenith. They have a customer service post available here
Posted on Mar 30, 2008
Th3_uN1Qu3
  • 47 Answers
SOURCE: White lines across screen and color faded.
Those lines are called vertical retrace lines. They appear when the G2 (screen) voltage is set too high, or when the video amplifier fails or lacks the high voltage supply (200v).
Have you got any electronics experience? You will need a multimeter and soldering skills.
If you do or know someone who does, take the set apart, look at the video amplifier IC (it is on the board at the back of the tube), get its model and download the datasheet. Find the pin that is labeled "high voltage supply" and with the set turned on measure it against the one that says "ground". You should have somewhere between 180-210v there. If that voltage reads zero or a very low value, the amplifier circuit is shorted or the power supply is not working properly. Unsolder the video amplifier and measure again, if the voltage comes up then buy a new amplifier IC, if it doesn't it's time to check the power supply. I believe you can find a service manual easily, follow the directions there.
Safety precautions: Do not under any circumstances touch the leads of any capacitors, and stay away from the big fat wire going to the top of the tube. Do not do anything inside the TV while it is plugged in (except measurements), and always use well-insulated tools. The high voltage section of the TV does not pose any health danger, however the shock it can give you will make you jump back, possibly into something sharp.
Posted on Jun 26, 2009
bhatgiri73
  • 106 Answers
SOURCE: DVD viewing shows in black and white
you have to change color system of dvd(ntsc, pal,) normally dvd remote will p/n button..press it to change color system,,otherwise u have to change color system of ur tv
Posted on Mar 15, 2010
Why is my screen red when it should be black?
Search Results
    Philips Magnavox 8p6031c Crt Lens Fluid Repair Questions ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/page-11
    Recent Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & answers. Free expert ... Philips flat screen tv, Red flashing light. Light.
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Repair ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/popular
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & fixes. ... My son accidentally spilled water on our Philips tv and when i turned it on ... I need a screen replacement of philips tv 60" ... Why the tv come on but a min after the red blinking come on an it turn off by it self what the problem?
    Magnavox Projection TV problem... ' Techlore
    www.techlore.com/forum/thread/.../magnavox-projection-tv-problem
Jan 13, 2016 | Philips Magnavox 8p6031c Crt Lens Fluid...
Hello, I have a Magnavox tv 32" model 32mt3305/17.
you should bye a surge potecter power cord.surges happens all the time and destroys electronics
Aug 17, 2013 | Philips Magnavox 27MS343S 27" TV
II got a Magnavox ditgit ax box 4 my tv from a friend and they had no manual. Can I please have one dent 2 me? he model # is tbllomw9
Hello
Just surf through this website and try to get your Philips TVs manual. If you fail to download it from there, send ma a mail, or send your email ID to me by Fixya. i've the manual you need, and will send it to you by return mail. OK.
deltamanual.com/.../philips-magnavox-50ml8105d-50-in-hdtv-dlp-tv-dlp- magnavox-manual-tv.html
Mar 18, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a philips magnavox model HD1918 C125 that only has a jack for cable/antenna. How do I hook up a DVD player?
Go to a tv repair store, they sell RF Modulator that is made to work with your tv, and comes with everything you need to get hooked up and running, and is reasonably priced.
Jan 28, 2011 | Philips Televison & Video
PHILIPS MAGNAVOX PS1963 C121
Hello
"Philips Magnavox PS1963c121". That is all. What shuld I do with It? Please give me details of it problem. Without it what should I do?
Jan 06, 2011 | Philips Magnavox 27MS343S 27" TV
I need a new remote for a 20ms3442tv
Hello
You just buy one Philips Universal Remote control Model [CL 034] for your Philips Magnavox TV. Both Philips and Maganvox are listed in it manual. OK.
Jan 01, 2011 | Philips Magnavox 20MS3442 20" TV
No picture and no sound. Only the power light comes on.
This sounds like it began as a deflection problem and now has become a shutdown problem. due to excessive current (possibly due to the deflection problem becoming worse). if this is a deflection problem it may be a problem on the deflection board or in one of the yoke transformers which are usually connected to the deflection board. In any event I would suggest that you get a qualified TV technician to troubleshoot and repair this TV, due to the nature of this issue.
I hope this helps
shuttle83
http://www.electron-age-technologies-llc.com
Nov 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips/magnavox 20 in tv
check the horizontal output transistor or the vertical IC,maybe one of them is defected .
Oct 30, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox(model 9P6034C102 )
This is any easy fix. Goto www.magnavoxhelp.com to get a repair kit. Its a common problem on some of the older Magnavox projection TV sets.
Jul 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 13MT143S
Hello.
I believe from your description that the vertical circuit has failed. either the IC or a capacitor. Sorry, but being only a 13" set I don`t recommend you repair it. unless you have a friend that would do it for you for the cost of the parts only.
Feb 26, 2008 | Philips Magnavox 13MT143S 13" TV
Televison & Video Logo
173 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
