Question about Canon S200X Ink-Jet InkJet Printer
Waste ink absorber is full
As I am printing on my Canon 9900 the printer stops and then a message says the waste ink absorber is full. How do I replace or clean it?
Also, I am getting black ink tracking over a job. Is this also related to the absorber being full?
  • Abhijit Muchandi Nov 28, 2011
    wil it be work for ? Ink absorber full brother DCP-J125
    Guru:
  • Canon Expert
  • 183 Answers
Hi!
The printer counts every single droplet ejected by the print head due to waste ink absorber capacity. When the waste ink counter rise to about 90 % the printer shows message 'Waste Ink Absorber Near Full'; in this stage we can still continue printing by pressing Resume button until waste ink absorber capacity reach 100% and 'Waste Ink Absorber is Full' appears.
To fix this problem you have to reset waste ink counter to 0%. Even though we can just reset waste ink counter without resetting waste ink counter, it strongly recommended that you replace waste ink absorber to prevent ink flooding inside the printer.
To reset waste ink counter, perform the following steps:
  • Plug in power cable
  • While pressing Resume button press and hold Power button (do nor release the buttons)
  • Release Resume button (still hold Power button)
  • Press Resume button twice in a row (still hold Power button), after that release both Resume and Power button (then the printer standing bye)
  • Press Resume button 4 times then turn off the printer
In this stage your printer has operated as usual.
Regards,
Posted on Dec 02, 2008
Posted on Apr 09, 2009
Canon i9100 clear error message "waste ink absorber"
I am so proud of myself for doing this. Canon wanted me to take it to a service center, which would cost more than it\'s worth. I DIY\'d the sucker!
First I had to open up the machine, which was not easy.
1. Open cover so carriage comes to center, as it does when you change ink cartridges.
2. Unplug without powering down
3. Undo the usb and take off the plastic plate that is in the back left, where the usb plug is. It\'s a separate piece from the rest of the cover.
4. Next you want to take the full cover off. You\'ll need several flat head screwdrivers for this next step. Put the screwdrivers into the tab holes that are marked with an arrow. There are 2 in front side, one on each side and one on the back right, all near the bottom of the machine. Don\'t pry it off but gently coax the tabs so they release the cover. You may need a 2nd person for this.
5. On the i9100, there are two screws in the back left and right, holding the entire carriage and ink cartridges. These are the only 2 screws holding the machine guts to the bottom plastic piece. Looking at it from a top view, the screws are pointing straight down, not into the sides.
6. There will be a bunch of wires connected to the machine guts. When you lift up the unit, be careful not to break any of the wires. I just swung the inner guts around, so it was still connected but now I was able to get to the waste ink absorber pad, which covers pretty much the whole bottom.
7. You\'ll need gloves as you pull out the pad. It is VERY full of ink. I washed it in water for a good 5 minutes, squeezing and rinsing out as much ink as I could (in my basement slop sink). I put the cleaned pad on towels over my radiator to dry, which took 1.5 days.
8. I reassembled the whole thing, although the pad shrunk a bit. If you can find the pad, it might be worth buying a new one.
9. I followed Xanda\'s steps to clear the error message.
10. But in clearing the message, my printer driver had to be re-installed, which I got from the Canon website.
It works perfectly now!!!
Posted on Jan 30, 2013
  • Kitz Willy Jan 30, 2013
    I am so proud of myself for doing this. Canon wanted me to take it to a service center, which would cost more than it's worth. I DIY'd the ******!
    3. Undo the usb and take off the plastic plate that is in the back left, where the usb plug is. It's a separate piece from the rest of the cover.
    4. Next you want to take the full cover off. You'll need several flat head screwdrivers for this next step. Put the screwdrivers into the tab holes that are marked with an arrow. There are 2 in front side, one on each side and one on the back right, all near the bottom of the machine. Don't pry it off but gently coax the tabs so they release the cover. You may need a 2nd person for this.
    7. You'll need gloves as you pull out the pad. It is VERY full of ink. I washed it in water for a good 5 minutes, squeezing and rinsing out as much ink as I could (in my basement slop sink). I put the cleaned pad on towels over my radiator to dry, which took 1.5 days.
    9. I followed Xanda's steps to clear the error message.
BROTHER P-TOUCH IS not printing
It is obvious it has a failed electronic component, since these are not repaired/exchanged except when they are under warranty best thing to do is just replace it.
Jan 09, 2017 | Brother Office Equipment & Supplies
How do I connect two computers to my Canon MX3520 printer?
in the control panel where you see add a printer, you have to add the printer to each computer then click on the share printer box
Jan 09, 2017 | Canon Office Equipment & Supplies
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Why is print quality poor after inserting new ink. Copies are faint and have lines
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
May 07, 2014 | Office Equipment & Supplies
Canon mg6150 printer too much pink in photo's when printed
Please calibrate the printer using Canon software.
Mar 08, 2014 | Office Equipment & Supplies
Prinnter not printing but showing 'put custom in manual tray'
There is still a print job in the queue. Place a sheet so it prints or kill the job.
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.
For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start. This may have to be done from the Print Server if it's network printer. Contact IT to kill.
Nov 09, 2012 | Office Equipment & Supplies
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
Why does canon MP258 printer with scanner can't scan japanese yen paper bill amount 10,000. I tried it over 10 times but it stops,. And when i tried US paper bill, it works well. I need some explanation...
When you scan with any scanner it utilised the software with "Optical Character Recognition functions, usually abbreviated to OCR -> OCR is a field of research in pattern recognition, artificial intelligence and computer vision." to scan and record the scanned object, sometimes it does not or cannot recognise certain symbols or characters because of man made software & hardware have its limitations too.
Hope it helps.
Nov 12, 2010 | Office Equipment & Supplies
Canon S200X Ink-Jet InkJet Printer Logo
3,377 people viewed this question
old marine
old marine
