I have a wireless headphones the only number i can see is model f0461b on the trasmitter. The transmitter and headphone are not comunicating the lights are red not blue.How do i recalibrate them so they are working i did this before but i dont rember how i did it Please help
  • junkmail342 Dec 19, 2008
    They are Logitech F-0461B. There is a single button on the base unit, along with a small reset button, while the headsets have a power button, and volume up/down buttons.
    No combination of the above seem to switch the once blue lights back from their current angry red color.
In rare cases, the FreePulse Headphones may loose synchronization with the receiver. If this occurs the following steps will re-establish the connection by putting both the headphones and the receiver in discoverable mode (actively searching for another bluetooth device it can connect to).
Putting the headphones in discoverable mode:
Press and hold the power button (located next to the charging port on the right earpiece) on the headphones. The LED on the button will go through three states in this order:
  • Blinking Red
  • Off (continue to hold. the LED will be off for several seconds)
  • Alternately blinking red and blue. (The headphones are now in discoverable mode and you can release the button at this point. The headphones will remain in this state for 30 seconds).
Putting the receiver in discoverable mode:
Press and hold the power button (located on the side of the receiver opposite the headphone jack).The LED on the button will go through three states in this order:
  • Blinking Red
  • Alternately blinking red and blue. (The reciever is now in discoverable mode and you can release the button at this point. The reciever will remain in this state for 30 seconds).
Re-establishing the connection:
To re-establish the connection between the headphones and the reciever, put the headphones and the receiver in discoverable mode at the same time. It will take a few seconds for the two devices to establish the connection. Once the connection has been established the LEDs on both the headphones and receiver will glow solid blue.
Posted on Dec 27, 2008
How do I connect a wireless head set to a Dynex Television Model DX-37L200A12
Using the appropriate cable for the transmitter that came with the wireless headphones, connect one end of the cable to the AUDIO OUT jack on your TV set and the other end to the AUDIO IN jack of the transmitter. If your headphones came with rechargeable batteries, don't forget to charge them before using the headphones.
H
Dec 08, 2014 | Dynex Computers & Internet
Can I pair Bluedio Q9 with Bluetooth transmeter?
all depends on the quallity and age of the transmitter, go to youtube ad type in the make and model of the transmitter and chances are someone there will have posted a video instruction for it...
thank goodness for egos ;-)
May 17, 2014 | MOBILESW Bluetooth Stereo Headset Bluedio...
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
How do I get my Slick HP 921 Wireless headphones to work
  • Goodmorning, I received Slick HP921 Wireless Headphones yesterday I have perfectly utilized them yesterday but today I have no communication between the wireless transmitter and the wireless headphones without changing anything since yesterday.
    The wireless transmitter is turned on but it's not trasmitting. The headphones work perfectly with fm mode and also when i connected the single green plug with other devices ( pc, phone ).
    The problem should be in the wireless transmitter.
    What I have to do ?
Dec 26, 2012 | Audio Players & Recorders
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
I bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Sep 23, 2012 | LG 32LG30 32 in. LCD HDTV
Wireless infrared stereo headphone no sound
You do not need to tune anything. Both transmitter (in your DVD player) and headphone operate at the same frequency.
The only thing I could think of is to check your DVD player's menu to make sure the transmitter is activated. And make sure you maintain line of sight between headphone and transmitter.
But rather then me guessing since you did not provide the model numbers of your products, why don't you contact XO Vision's customer service as listed on their website: http://www.xovision.com/contactus.php
Good luck.
Nov 08, 2009 | Audio Players & Recorders
Samsung's yp-t10, can it be paired with freepulse?
Yeah, they were quite well together i have them both.
To connect
1. Hold the switch button on the Free pulse until it flashes
RED & BLUE
2. Go to bluetooth setting in the T10 and add Headphones
3. Turn on headphones when turning on T10 should automaticaly connect.
Jan 06, 2009 | Logitech FreePulse Wireless Consumer...
Setup Bluetooth Wireless headphones
Each brand has it's own peculiarities and you did not specify the brand. I would suggest turning off the headphones, resetting the transmitter (turn off and on again for separate devices) and then pressing and holding the 'on' switch for 15 seconds or so. You may see (in some models) a light start to blink blue then red and back. This should indicate that the receiver (headphone) is trying to find a transmitter to pair with. Hope this helps.
Nov 27, 2007 | Logitech Bluetooth Wireless Headphones
Wireless headphones
If you're handy, you could rig up a wireless solution to this. The problem is that you have two screens, each presumably playing a different movie. If you purchased an off-the-shelf wireless transmitter accessory, you could connect it to one of the screens. But then if you purchased a second wireless transmitter accessory, and connected it to another screen, you would need to make sure both wireless transmitters were operating on different frequencies, so that each person could wear a different pair of headphones and listen to their own movie. Hopefully this makes sense. You could use either an FM Modulator to do this, or an Infrared Audio (IR) transmitter... Remember, these units aren't like factory installed headrest systems; they don't have the wireless audio transmitter already built-in, so you can't just buy wireless headphones and listen to them.
Aug 17, 2007 | Venturer PVS62911 Car Video Player
893 people viewed this question
 Grubhead
Grubhead
