Question about Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW (2018267632) PC Desktop
Screen does not stay on it just flashes on every four sec
When i turn on comp the screen does not stay on it just flashes on every 4 sec then al of a sudden it will turn on by its self and will work fine but after it goes into screen saver mode the problem begins
Sounds like the refresh rate of your video adapter is set incorrcetly, especially if the monitor is new to the system. CRT monitors could handle a wider rate range than the current LCD's.
The next time it starts working correctly, go to "display settings" and check the "monitor" tab. For a LCD monitor, the refresh rate should be between 60 and 72. Experiment with the different rate settings to optimize your display.
Hope this helps
Posted on Nov 20, 2008
On the screen is only /attention / entering sleeping mode/no video input what is a problem?
1.This means that your comp is supplying power to the comp...
2.check video cable...unplugg and replugg...
3.Still not resolved...unplugg all the devices from the back including the power cable...
4.then press and hold the power button for 20 sec...then connect the power cable keyboard mouse and the monitor cable...
5.then try to start the comp...
6.still not fixed...switch the voltage selector at the back...
7.still not fixed need to reset the ATX cable inside the comp...
8.Still not fixed can be a hardware problem...
Apr 06, 2011 | Computers & Internet
HD56W66 powers on screen flashes foe a few sec.
On your Deflection board Look for Bad capacitors CP150 2200uf 16v CP114 CP120 in same circuit they will be puffed up on top if they are replace all 3 capacitors.other 2 are 220uf 35v and 330uf 35v
Mar 17, 2010 | RCA HD56W66 56" HDTV
My 200i not start up
ur phone has virus if u couldnt remove it safely so you go to ur mobile expert and get a consultation
Feb 20, 2009 | Sony Ericsson W200i Cellular Phone
When i hook up my comp the monitor stays black...whats going on?
Try remove your VGA card and reinsert and test. And if the problem persist then test your monitor to the other PCs and if it displays then it could be the card is bad or the monito's resolution was ajusted causing to be uncompatible for your PCs resolution.
Nov 22, 2008 | Computers & Internet
Red light flashes four times
4 red light flashes normally means there is a problem with the fan. Time to make a service call.
Dec 19, 2007 | Sony KDSR50XBR1 50" Projection HDTV
The screen is white
This is the internal video card of the monitor.
It has either failed, or the cable that connects it to the LCD panel has come out of either the video card or the panel.
Hope that helps =)
Sep 19, 2006 | BenQ FP757V2 (Black, Silver) 17 in. Flat...
Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW (2018267632) PC Desktop Logo
54 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
