Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven door staying open about 1 inch
My oven door will not close all the way since my son decided to lean on it. I have had the door off and I cannot see anything wrong. Please help.
  • jillejill Mar 27, 2009
    frigidaire gallery model fcs388whcc seems not to be closing all the way...light in oven stays on and will not self clean...it gives message "door"...what can i do to fix this? I tried turning the circuit breaker off and back on...didn't help. Thanks!
    mode number fcs338whcc
  • 116 Answers
You need to post the model number for the stove
Regards
Posted on Nov 22, 2008
Oven door won't quite close tightly. I can push it about another 1/4 inch to close it completely.
You need to replace the hinges in the door. Go online to a spares website and enter make and model and order new hinges. You can replace them by unhooking the door, just takes a little effort, you might need to flick back latch on hinge and lift out. Remove inner door panel, usually 4 screws and remove. then change hinges. The 2 big pieces are the hinges.
  • images?q=tbn:and9gcsg1plmaxnucdapg-xpimmjauz_p4kgblmyf6iotcmgyh-hv4v3
Mar 09, 2011 | Ovens
Double oven top door will not close
you need to change you oven hinges, change them as a pair cost around £40.00 to buy, not a hard job to do
Apr 07, 2010 | GE Profile JTP56 Electric Double Oven
Oven door will not close completely stays open about 1/4 inch
Hinges may need to be replaced. Rule of thumb, if one is changed, change the other as well. Also try WD40 open and close continuously, it may be stuck. But you will eventually have to change the hinges. Good luck.
Sep 03, 2009 | Bosch Ovens
your going to have to replace both the door hinges, since they have been over extended past ninety degrees they are not able to close to ninety degrees. that is the only repair, i would also look closely at the inner door panel and make sure that is not "crowned" or bent from the force that might also need replacing
Nov 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Doors will not stay closed all the way
I think this is a cheapest and eat way to fix your oven doors... Otherwise there are 2 spring type locks of the door that starts getting old day by day ... You have to change the pair of lock only
Apr 05, 2008 | KitchenAid Architect® KEBS277S Electric...
Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Oven door stays slightly open
The unit may be out of plumb ( square to the floor ). I suggest you get a level and make sure the stove/oven is level and if it's not, there are some levelers ( where legs would be on the bottom ) that can be adjusted with needle nose pliers or a cresent wrench. If this doesn'e work, you may have some hinges sprung and need to replace them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jenn-Air single electric wall oven #JJW9530DDS
try to open the door see if the door latch is extended if it is locate the light switch on the oven cavity and hold it in then hit start then cancel or stop the latch rod should go back
Dec 27, 2007 | Jenn-Air JJW9530C Expressions Collection...
Kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Nov 22, 2007 | KitchenAid KEBC208 Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
106 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
