Scan Error Adapter Unavailable error when I attempt to find WLANS I have an MC70 device with the same error. Will a soft boot delete what's stored on the Flash card? Will a hard boot delete what's stored on the Flash card?
  • Anonymous Dec 30, 2008
    I have exactly the same problem, with a MC70 Symbol.
A hard boot didn't seem to delete what's stored on the Flash card. I was able to retrieve the data I needed.
Posted on Nov 20, 2008
Scan error adapter unavailable for motorola mc75
For this problem contact the mobile service provider.........
Dec 03, 2011 | Cell Phones
How do i completely rest the mc70
you need to use a piece of software from motorola, follow the link below and download "MC70cleaners"
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11744&sliceId=&dialogID=175684178&stateId=1%200%20175682106
unzip it onto the root of an SD card, put SD card in EDA,press power +1+9 together after 20 seconds release them, press top right button, updater will start, u need the mains plugged in, after it has finished it will boot into windows mobile.
Aerv 74
Apr 23, 2010 | Symbol MC70
My work has given me an mc70. how do i connect to the internet? mcdonalds has free wifi in australia and would love to know how i could set it up so that i can log into the internet when i am at mcdonalds....
There are a few variants of the MC70.
MC7090 - the 9 defines the Wireless function.
MC7004 - the 4 defines the phone function.
Hence a MC7094 would have wireless and phone functionality. If you have a "9" version then you can use the free wifi. There would be a PCMCIA card symbol in the bottom right hand corner of the device. Click that and "find WLANS". Then connect to the one you want.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Mar 25, 2010 | Symbol MC70
How do i get rid of the KERNEL_STACK_INPAGE_ERROR on my d600? Occasionally it says UNMOUNTABLE_BOOT_VOLUME instead. Help?
This issue can occur if a requested page of kernel data could not be read from the paging file into memory, or the master boot record is infected with a virus. To further determine the possible cause, you must properly interpret the error message. If both the first and third parameters are zero, then the four parameters are defined as:
  1. 0 (zero)
  2. Page Table Entry (PTE) value at time of error
  3. 0 (zero)
  4. Address of signature on kernel stack
If either the first or the third parameter is not a zero, then the following definitions apply:
  1. Status code
  2. I/O status code
  3. Page file number
  4. Offset into page file
If this is the case, the cause of this issue may be determined from the second parameter (the I/O status code) by using the following information that is listed in a "value of second parameter" followed by "general cause" format:
0xC000000E, or STATUS_NO_SUCH_DEVICE: the drive went unavailable, possibly a bad hard drive, disk array, and/or controller card.
0xC000009A, or STATUS_INSUFFICIENT_RESOURCES: lack of nonpaged pool resources.
0xC000009C, or STATUS_DEVICE_DATA_ERROR: bad blocks on the hard disk.
0xC000009D, or STATUS_DEVICE_NOT_CONNECTED: bad cabling, non-termination, or the controller is not able to obtain access to the hard disk.
0xC000016A, or STATUS_DISK_OPERATION_FAILED: bad blocks on the hard disk.
0xC0000185, or STATUS_IO_DEVICE_ERROR: improper termination or defective cabling of SCSI-based devices, or two devices attempting to use the same IRQ.
To resolve this issue, use the appropriate method:
Boot sector virus loadTOCNode(2, 'resolution'); To determine if you have a boot sector virus, run a current virus-checking program, and if needed, disinfect your computer.
Not a boot sector virus loadTOCNode(2, 'resolution'); View the System Log in Event Viewer for additional error messages that help you determine the device that is causing the error.
Bad block. Stop 0x77 is caused by a bad block in a paging file, or a disk controller error, or in extremely rare cases it is caused when non-paged pool resources are unavailable.
If the first and second parameters are 0, then the stack signature was not found in the kernel stack. The cause of this issue is defective hardware. If the I/O status is C0000185 and the paging file is on a SCSI-based hard disk, you should verify the disk cabling and SCSI termination.
If the I/O status code is 0xC000009C or 0xC000016A, this normally indicates that the data could not be read from the disk due to a bad block.
If you can restart your computer after the error message, Autochk runs automatically and tries to map out the bad sector. If for some reason Autochk does not scan the hard disk for errors, manually start the disk scanner. If your computer is formatted with the NTFS file system, run Chkdsk /f /r on the system partition. You must restart your computer before the disk scan begins. If you cannot start your computer due to this issue, use the Command Console and run Chkdsk /r.
Defective or unreliable random access memory (RAM) is another common cause of this issue.
Verify that all the adapter cards in your computer are properly seated.
Ensure that all adapter card contacts are clean.
Disable system caching in the BIOS to see if this resolves the error.
If this does not resolve the issue, your computer mainboard may be damaged.
Oct 23, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
M7094 Warm Boot Error
Go to devzone.symbol.com, then click on the "Click here to enter Support Central" link. From there enter "clean boot" in the search box and select "Mobile Computers" in the Product Line drop-down and MC70 in the Product drop-down. Then click "Go". When the results are displayed, choose to sort by "Most recent" instead of "Most relevant". Then the first entry will be the clean boot files for if your device is running WM 6.1, and the one that's about 5 entries down will be the clean boot files for if your device is running WM 5.0.
Sincerely,
Brad Radaker
Radicomm, Inc. (makers of QuickTalk, push-to-talk over WLAN for rugged devices like the MC70)
www.radicomm.com
Jul 21, 2009 | Symbol MC70
Windows Mobile Symbol Find WLAN error
Warm boot the MC55 if that doesn't help then cold boot it, if that doesn't help then reload the Operating system, if that doesn't fix it then send it back to Motorola for a warranty repair.
Jun 02, 2009 | Symbol MC9090 Barcode Scanner
On my PDA MC70 it is showing WI-FI "unavailable"
This can get kind of complicated, and your wireless carrier may block this depending on the data plan. It's also different for the MC7095 (CDMA) and MC7094 (GSM/GPRS) models. You may also want to see if your device BSP release is up-to-date.
Here is some basic info for the MC7095 (Sprint):
Device was not connected to network to start.
Went to Start, Programs, Internet Sharing, tapped Connect, showed Status: Check USB connection. Internet Sharing drivers were installed on laptop computer, then device displayed Internet Sharing Status "Connected". We were able to browse the web on the laptop computer. Closed out of Internet Sharing (tap X on upper right hand corner). On device, tapped Start, Internet Explorer, attempted to browse to a webpage. Able to browse on both laptop computer and MC7095 device.
Note: Attempted to Disconnect the Internet Sharing session, unable to. The device does not appear to respond to the "Disconnect" option on bottom left of screen. When tapping "Disconnect" the option light up as if being tapped however the device itself shows no other changes and Status still displays :Connected.
***FYI*** In testing with a different MC7095 (BSP33) we experienced the same issues with not being able to "Disconnect" the Internet Sharing session.
Jan 29, 2009 | Symbol MC70
MC9090G "Find WLANs" got error Scan Error. Adapter Unavailable
I had the same problem and I did a cold boot and the wireless icon showed on on the 'desktop' and I was able to use it again.
to do a cold boot, turn off the unit, remove the battery, pull the trigger and hold the power button for 5 seconds or so, and put the battery back in.
Jan 14, 2009 | Zebra Symbol Technologies MC909X-G Series...
Scan Error
Rebooting while an ActiveSync connection is made can cause Adapter Unavailable to be reported after the reboot is complete until either ActiveSync is connected again, or the date is manually changed.
Sep 24, 2008 | Zebra Symbol Technologies MC909X-G Series...
Computers & Internet Logo
1,331 people viewed this question
Alun Cox
David Payne
David Payne
