Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool gas dryer won't ignite -no heat
Not long ago (6mos.)I replaced the two solenoicoilst coils on the gas valve. Do you think that they need to be replaced again. I do not see anything glowing like it is attempting to light. Perhaps it doesn't try to light when it knows that the gas valve is closed? The dryer exhaust line is clean. I have the same results with the line disconnected. I have replaced these coils twice before. Thanks for your help, Dennis
  • 370 Answers
Try replacing the ignitor. The ignitor has to glow red and draw enough current to open the gas valve. When the gas valve opens then the ignitor lights the burner. Replace ignitor.
Posted on Nov 19, 2008
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Model not getting hot.
Common causes of no heat in this dryer
Igniter
Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Feb 26, 2011 | Whirlpool CGM2751KQ Gas Commercial Dryer
Dryer doesn't heat up
Hello there
PLEASE READ THE ENTIRE SOLUTION
If your dryer doesn't heat, check these: Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Sep 28, 2010 | Whirlpool GGW9250PL Gas Dryer
Igniter comes on but no flame after that. Possibly bad valve coils but I think this particular gas valve model WE01X10201 does not have replacement coils in the market yet. The solution I am geeting is...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 24, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Gas dryer-no heat. whirlpool lgr4634eq3. can i
Advise your landlord of the issue and follow his/her instructions.
I have provided some information on trouble shooting the dryer No Heat issue.
Below is a checklist provided by; www.repairclinic.com.
They also provide repair parts, disassembly procedures and diagrams for DIY repairs.
Firstly, ascertain that you have made a positive heat selection, then read on.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Igniter
Gas valve coils
Thermal fuse
Jul 12, 2009 | Whirlpool LGR5636L Gas Dryer
Hello, My fairly new whirlpool gas dryer does not heat. I replaced the thermal fuse a month ago and the heating problem was resolved, now no heat again, thermal fuse was tested good. The igniter will turn...
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Jun 14, 2009 | Whirlpool Dryers
No heat in dryer
May 11, 2009 | Dryers
Gas Dryer quit heating today
Just click below;
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Whirlpool LGR8648 Gas Dryer
Does not heat
There is NO starter on a gas dryer burner assembly. The burner is controlled by gas valve coils and a glow bar igniter. Once the igniter reaches the appropriate current level, the gas valves open and you have ignition. The common problem is a weak igniter. You need to do a current measurement to make sure the igniter is within tolerance. If it is within specs, then I would agree with docjohn174 about replacing the coils. If its not within specs, you need to replace the igniter. Depending on the type of igniter you have, the current rating is as follows:
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
I still need an accurate model number in order to confirm WHICH type of igniter you have.
Oct 03, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
149 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
