Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet Model # ghw9400pwo ser# csr4213541 type 199 085 wt/gy Greetings: During the spin cycle the washer alarmed and a code came on the screen the letter F what does that mean? I opened the door after hitting pause thinking this would reset it and it did it finished the cycle however with the second load it did the same thing. Does F stand for filter is there a filter in the washer. We recently got 2 dogs and perhaps the dog hair has clogged the filter? Let me know your thoughts
  • djshirley Nov 22, 2008
    There are no screws along the front bottom of this washer..can't figure out how to remove this lower panel without breaking it-it may not be something that is removable.
    President:
  • Whirlpool Master
  • 2,651 Answers
You can remove the lower access panel of unit ( 3 screws across the front bottom of unit), behond there directly in the middle of machine yuoll see large plastic turn screw. that s teh pump housing "filter cleanout". unscreww and clear all debris. be aware however if theres water in machine it will come out on you when you release teh turnscrew
Posted on Nov 20, 2008
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
Whirlpool duet ht will not agitate or spin
Front load washers don't "agitate". Did you mean it doesn't tumble during the wash cycle? I need more information. Complete model # and a more detailed description of the issue.
Mar 16, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
Loud knocking and vibration during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Duet washer model 6GHW9100LW that has been spontaneously filling with water, even though the machine is not turned on...bad valve??
have a Duet washer model 6GHW9100LW that make made a rapping noise during the spin cycle. It get louder as it spins faster.
Dec 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Very Loud and Active Whirlpool Duet Sport Washer
It looks like the transit bolts are still in there at the back and if you take them out it should be more quiet.
Dec 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Model No. GHW9100LW, Serial No. CSM2608446, Type No. 199-AWM075/GY
not unless you make it yourself ..replacement handle is just like the 1 that broke
Aug 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
232 people viewed this question
Dan Webster
Dan Webster
Sal De
