Question about GE Spacemaker JVM1640SJ Microwave Oven
Cannot heat I was making popcorn when my microwave completely died - no power at all. I check the breakers, the breaker hadn't tripper. I reset the breaker and unplugged and plugged the microwave and all peripheral on my microwave - clock, fan, lights etc work fine. There is no heat - water doesn't boil when I turn the microwave on. It seems to make the regular noises - I cannot distinguish if it is just the turntable rotating or the magnetron kicking in with a "bong". Any suggestions. The microwave is about 4 years old but has minimal usage over the four years.
  • GE Master
  • 9,149 Answers
Sounds like it overheated, tripped the thermostat, then the thermostat reset. Chances are you have a bad magnetron. GE may have a campaign (not a "recall", mind you!) to offer free replacements if yours is a model that has a known history of problems with the magnetrons. I would call GE and ask them about that. *grin* GE Answer Center 1-800-626-2005 24 hours a day, 365 days a year
Posted on Dec 14, 2006
    New Friend:
  • 23 Answers
The mag's little cooling fan probably broke loose and fell off the fan motor's shaft. The fan motor is running but there is no fan on it. The fan keeps the mag cooler. The machine shuts down when the mag gets too hot because the fan blade is just lying in there, Needs to be glued back on the shaft after the shaft is roughed up a little. NO other parts needed. I used contact cement to hold the fan to the shaft. It is located right behind the control panel. It's not difficult to repair.
Posted on Jun 12, 2013
4 Suggested Answers
  • 17 Answers
SOURCE: GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
Posted on May 17, 2008
tbirdfan1
  • 3051 Answers
SOURCE: My microwave suddenly has no power, clock etc. I
Hello there and thank you for choosing fixya:
This is a very common issue with microwaves
Yes you are right it does indeed have a fuse inside of it
you first need to unplug it of course then take out all of the screws that are along the outer edge on the back there may be 4 or 6 ok next there are 3 or 4 screws that are on the sides that need to be removed ten if you take a small flat tip screw driver and insert it in the seam at the top towards the front you should be able to slide the cover back about 1 to 2 inches then it will lift up and slide off
Next if you look towards the front on the same side as the power panel yuwill see a electronic board it has the fuse on it it looks like this picture i have below simply remove the fuse and replace it WITH THE EXACT TYPE OF FUSE OK
then plug it in and ensure every thing is working if so great go ahead and unplugit again and put the cover back on ok but if not please post me back so i can continue the troubleshooting from there ok ? here is the pict
Best regards mike
Posted on Mar 04, 2011
heatman101
  • 43501 Answers
SOURCE: Our two year old GE
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101//
Posted on Mar 15, 2011
Will not heat food
HELLO.
The solution to make your microwave oven to be able to heat food is detailed given below.
1 Make sure the door is closed. If the door is not closed tight, the microwave will not function.Sometimes food will get stuck in the door and prevent the latch from working. Use the paper towel to get the food out, then close the door carefully and listen for the latch to click.
2 Check the power sources. First, make sure the microwave is plugged in; the plug may have shifted or slipped partway out of the socket. If it is plugged in and still does not work, voltage test the outlet the microwave is plugged into. If you are not getting a reading, the breaker is probably blown. Reset the breaker for that outlet in your home's circuit breaker box.
3 Reset the microwave breaker. Take the back cover of the microwave off with a screwdriver. Inside you will find a motor. Most microwave motors have a small red reset button on them. Hit that button. Your microwave should work again if the breaker was the issue.
Thanks
Sep 20, 2011 | Frigidaire Microwave Ovens
Microwave, kenmore 721.89822, will run when powered, but will not cook, no microwaves
HELLO.
Follow some straightforward troubleshooting steps to make your microwave work like new again.
Thanks.
Sep 18, 2011 | Kenmore 80822 80823 80824 80829 1500...
I was just using the microwave and it died on me. No power to the unit that I can tell.
Check the circuit breaker. If it's pugged into GFCI type outlet or an outlet that's run from one, make sure the breaker didn't trip there.
Mar 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
18 years old, microwave suddenly died
When you say that you checked the circuit breaker, can I assume you meant the one for your home? There is a fuse in the microwave. Typically it is a 20 Amp fuse. To check it you will need to open the cover. A word of warning, there are some high voltage components like the capacitor that should be discharged before working on this device. If you are not familar with electronics, then you should take it to a qualified service person.
Jun 16, 2010 | Microwave Ovens
My microwave shut off after microwaving two popcorns. what do i do? Did i break it?
unplug the microwave and plug something else into that outlet to be sure you have power there. If there is no power you will have to reset the circuit breaker or change the fuse in the electrical panel for the dwelling.
If the outlet is good most likely the internal fuse in the microwave will have to be replaced.
Oct 10, 2009 | Panasonic NN-S540 Microwave Oven
We have a JVM1870SF02 Microwave Oven. Everything
Is it on a gfci plug? If it is reset that. If not I would recheck the circuit breaker again
Sep 23, 2017 | GE Microwave Ovens
Keeps blowing breaker
Did you call Samsung's Service Division at 800-932-3837?
They may be able to give you a better number to call.
If you don't have them, you can download Samsung over the range microwave installation instructions here.
Please let us know what you find out.
Oct 22, 2008 | Emerson MW8987B/W Microwave Oven
Daewoo MT1510B problem
Chances are your magnetron is overheating, activating the magnetron thermostat, which resets and restores power when it cools.
Your manual may call for you to put a paper plate under the popcorn bag to heat better and to protect the turntable. (And always place the food slightly off-center on the turntable, for the same reasons!)
You should first confirm that the outlet reads about 110-120 volts AC and that the microwave is on its own breaker. If a microwave shares a breaker with another high current device (or even lights) it can affect operation.
Then be sure the microwave's internal cooling fan is running.
If this is an over the range model, it will also have a exhaust hood vent fan which you can turn on and off at will, but this is not the fan I'm talking about.
The internal cooling fan should be on whenever the oven is cooking. If not, the magnetron can overheat and eventually be destroyed.
The next issue is how long you've had the oven.
If it's within the 30-day dealer exchange period, I'd take it back for a new one pronto.
If it's within the full warrranty period (usually 1 year) Daewoo's service center should fix it free.
You can visit Daewoo online or call them at 1-800-323-9668 or 1-800-553-4355 to find parts or find your nearest authorized service center to have them do the work.
Oct 07, 2008 | Daewoo KOR-6115 Microwave Oven
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
553 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
