Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven door staying open about 1 inch
I have a Frigidaire self-cleaning oven with the smoothtop cooking top and the oven door does not want to close all the way. I have had the door off and I cannot see anything that would be stopping it from closing. I do not see any springs on the hinges and it has worked fine up until my son decided to lean on the door. I cannot figure out how to get it to close again and with Thanksgiving coming up I need my oven to cook dinner in. Can someone please help me with this?
  • lwmlnew Nov 19, 2008
    The door on my oven does the same thing. It was caused by my mother-in-law who lives with us accidently fell against the door while it was open. The springs are attached to the oven,not the door . Only two screws hold the door on . More than likely the springs are off or the hinges are bent . I have never faced this problem myself and I'm still looking for a solution without resorting to a service call from the dealer.
    President:
  • Frigidaire Master
  • 2,651 Answers
Your going to have to replace both the door hinges, since they have been over extended past ninety degrees they are not able to close to ninety degrees. that is the only repair, i would also look closely at the inner door panel and make sure that is not "crowned" or bent from the force that might also need replacing
Posted on Nov 20, 2008
My frigidaire self cleaning oven says F90?
Lift top - there is a quater inch button on the black box behind the door lock - use screwdriver to press the button in - resets
Sep 17, 2012 | Frigidaire 27 in. Electric Gallery Pro...
Tip
SELF CLEAN - FRIGIDAIRE OVEN
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
on Oct 09, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
How do you remove the door from a frigidaire gallery series double wall oven(self cleaning)?
Open the door and look at the hinges the connect the oven door to the oven body, on each side you will notice a piece that can be moved back and forth without moving the door, roll each side toward the oven body this should be the locked position, now try to close the door and you will notice the hinges lift up. At this time you need to pull up and push forward on the door and both hinges will come out.
Apr 24, 2012 | Frigidaire 30 in. Electric Gallery Series...
Maytag Frigidaire Electric selfcleaning oven slide in type 30 inch wide purchase in 2003 --cleaning lady cleaned oven,unable to pull open oven door -door is jamed shut ???
Hello
Let oven completely cool then try.Locks out for safety because of extremely high temperatures involved in self clean mode.
Feedback appreciated
Aug 05, 2011 | Frigidaire FEB24S2AS Single Oven
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
You need to post the model number for the stove
Regards
Nov 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
211 people viewed this question
Top Frigidaire Ovens Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
