Question about Nokia 1100
My phone has no song at all
When my phone rings you can't hear it ring all it's volume up it only vibrates
  • 51 Answers
Hi Kathnicks2
Have you checked your profile if its in silent mode? Also check the settings and in that check if you have selected the incoming call alert as ringing or vibrate. You can also check if your mobile is ok by trying to listen to ring tones in general. So, if you are not able to just listen to ring tones, then you will have to meet a service person who can get it right for you.
Posted on Nov 19, 2008
I have no ringing sound on phone, i have gone to settings, ringtones & sounds, the ringer is on, vibrate is on, when i get a call it vibrates but those not ring. is there a ringing volume somewhere?
Welcome to FixYa!
Volume up your phone using the Volume Key on the left side of your phone.
  • A volume bar will appear on the screen.
  • Press the Volume Key until you reach the desired volume level.
  • Tap the ICON on the right to switch between VIBRATE and RING.
  • Make sure that it is in the RING mode.
Thank you for using FixYa.
Have a great day.
Jas247
Jun 04, 2011 | HTC 7 Mozart Cell Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
CAN'T HEAR MY PHONE RING WHEN SOMEONE CALLS ME I HAVE TO PUT THE PROFILE ON VIBRATE
Each of your profiles can be set to different ring tones and different volumes, so whatever profile you have your phone set to, make sure you have it on a ring tone you can hear, and make sure the volume is turned up. Let me know if this doesn't work.
Jun 18, 2010 | RIM BlackBerry Bold 9000 Smartphone
Double ring tone issue
Go to the same place that you go to to put it on vibrate and scroll down to set ring tones/alerts and sms text and change the settings the volume should be set to silent.
Apr 20, 2010 | RIM BlackBerry? Tour 9630 Smartphone
I have just been given a RAZR phone as my old phone didnt like going for a swim. I have set the ring tone and I can hear it. the volume is set as high as it will go and I can hear the sound as I adjust it....
The problem you are experiencing is that your ringer/speaker is faulty,
The ringer/speaker is what sounds out when your phone is called or you receive a text message
The only solution is to have it changed
Problem solved!!
Thank you for visiting fixya
Feb 23, 2010 | Orange MOTO RAZR V3x GSM Mobile Phone...
I cannot hear my phone ring. It is set to high
Look for a setting that changes the ring from vibrate to ring. It's a setting different from that of ring volume.
Dec 11, 2009 | Cars & Trucks
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
No sound at all on my phone (not on silent)
I've had my phone for close on 2 yrs now so I know it quite well. Simple (and obvious) way to test if the phone rings is to ring it from a land line and listen out for the ring tone. Maybe you are not clearly hearing the ring tone from all the other noise around you- try some other ring tones that have varying notes. I downloaded some of songs I like. I found that makes it easier to hear. Don't go for rap music- I found that was the most difficult to hear. I've managed to transfer an mp3 song from my computer onto my phone and use it as a ringtone.
Another way to test the speakers is to play some music through the "entertainment" menu. That way you can test to see if the volume adjustment is working well. If you can only hear the music faintly (as well as all other sounds), then there is probably something wrong with the speaker.
Yes, mine has a green light that flashes occasionally. I think that is the phone checking the signal.
Jan 20, 2008 | Sony Ericsson K610i Cellular Phone
No sound when phone rings
I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
Jul 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia 1100 Logo
245 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
