Question about Gateway FPD1775W Monitor
I need a driver for gateway 17 in. wide screen monitor FPD1775W
I connected this monitor to my laptop and the resolution is bad. I can't reset the reolution to 1280x720 for best resolution.
    Novelist:
  • 100 Answers
You might want to consider a default settings reset. To refresh or reset the monitor back to default settings, unplug the monitor's power cord, and then press the the power button for five (5) seconds to drain any residual power. Plug in and then turn on the monitor. The default settings load.
Additional information about your monitor is available on the Gateway support website.
Posted on Nov 19, 2008
Can I increase the screen resolution on my EV700B monitor higher than 800x600? How?
Open Control Panel - Display - Settings tab - Screen Resolution move the slider to the right to increase the screen resolution.
If you cannot increase the screen resolution, it means the correct video driver was not installed generic VGA driver was installed.
In this case install the video driver for your graphics card and change the screen resolution.
Apr 14, 2011 | Gateway EV 700 17" CRT Monitor
The resolution reminder keeps popping up on my screen and no matter what I do it just keeps doing this over and over.The resolution is set correct at 1440x900. It does this mostly when I am trying to play...
My suggestion is to lower your resolution. In high intensity graphic type games it may be just a bit too much for your monitor to handle
I hope this helps you out.
Apr 09, 2011 | Gateway FPD1775W Monitor
Had a optimal resolution message on my laptop. I just closed it and now have no screen. have rebooted and still no screen. how can i get my screen back?
Hi,Well Try running it in safe mode,press F8 constantly as you power-up the system,you cant change resolution here but i think you can do system restore,if it does not work,try connecting to an external monitor with a higher screen size than yours,like if yours is a 14" inch look for 15" or 17" inches an connect to laptop select resolution and reduce it to the lowest 800x600 or lower,shut down,disconnect external monitor and restart.
Dec 30, 2010 | Gateway Computers & Internet
I want to put my laptop and connect it with Gateway monitor. What type of plugs do I need?
Spec of the monitor http://www.dealtime.com/xPF-Gateway-Gateway-Monitor-FPD1760
It will need the VGA cable (3-row/15-pin D-SUB), you need to look at your laptop monitor port to see what you have for the output.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
And you will need to set the laptop video signal to be at the native resolution of this monitor, which is 1280 x 1024 @60Hz.
Sep 10, 2010 | Gateway FPD1760 17" LCD Monitor
Ghost images and vertical lines on new FPD1775W monitor
You going to need a new logic board inside witch controls the signals from your video board on your computer. that is the only fix there is that i know of and I been around the block a few times with gateway.
thanks please do leave postive rating and feedback Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 09, 2009 | Gateway FPD1775W Monitor
My monitor does not display any color other than blue.
Check monitor button to select proper colours or reset it to factory settings
Sep 08, 2009 | Gateway FPD1775W Monitor
My monitor light comes on but there is no signal.
Isolate the problem. Connect the problem monitor into different computer. If the problem monitor worked on another computer, try connecting a CRT monitor to the problem computer. Once the display comes back, change the screen resolution.
Jul 29, 2009 | Gateway FPD1775W Monitor
Starlogic 17'' as dual display not clear
Check and see if your NVIDIA drivers are up to date. Then try changing the resolution on your laptop to match the native resolution on the monitor and see if it works. If it does then you will need to look for the option to set custom resolutions on each monitor so that you can have both devices working at diferent resolutions if 1 is wide screen and the other is not.
Let me know if this does not work and you need more help.
Apr 20, 2009 | Computers & Internet
Wide vertical lines on screen
Hello there!
First things First
1) If you can or have another monitor try and see if the problem persist.
2) RMS the monitor if you keep these problem in these particular monitor.
3) usually these, problems, its cause by a bad capacitor in the monitor motherboard, or resistor.
4) it is best to return the monitor.
Carl
Apr 25, 2017 | Gateway FPD1775W Monitor
Gateway FPD1775W Monitor Logo
1,039 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
