Question about Funai PY90DG DVD Recorder
Cant record from V+ box
I find the sound when i record is very low and i cant record from the recorded programmes on my V+ box without watching the film is this right or does the problem lie with the V+ box help
We just got our V+ box and the engineer noted the problem - he suggested we 'synchronise' (or something) the TV remote and the V+ remote.
Read the help to find out how to do this (something to do with volume plus and mute, then the code for ur tv).
I had to put in about 10 codes (there were about 40!) before i got the right one, but now the sound is spot on (and I love HD BBC - want to range around in the on demand stuff now to see what they got!)
Good luck and hope this sorts your sound problme as it did mine.
Posted on Feb 11, 2009
Problem with watching normal scheduled TV and recording programmes
If you have an indoor antenna connected to that particular TV, a slight reorientation can make a big difference.
Oct 25, 2015 | Humax Televison & Video
Cant record two programmes at once
Well no matter the DVR, you should be able to record 2 programs at once...but you CANNOT watch a 3rd live while they are recording...also, if your DVR is hooked up to more than one tv and someone is watching something else in the other room, it will not record 2 at once, either. You can watch RECORDED programming while 2 others are recording, but not live tv.
You might want to check how many "inputs" your DVR has...most have 2 which allows the double recording...if you have an older DVR maybe you only can do one at a time. On my DISH box, they call these "TV1" and "TV2".
Hope this helps.
May 14, 2011 | Televison & Video
Can the LG 990W VHS VCR receive digital TV signal
VCR is analogue, However you can still use it to record digital programmes when connected via a digital set top box. You can only record the channel you have selected on the screen. In other words, you cannot record a channel programme while watching another channel. I use mine on a second TV and when recorded I take the tape out and put it into my main TV for viewing at a later date. I don't watch too much TV so it works fine for me for the odd programme.
Dec 05, 2010 | LG MG64 VHS VCR
Recording and actually WATCHING the programmes I record
this feature its not from the TV is for DVR box, that storage the information on a hard drive inside, check your DVR model and number and google the proper manual for it
Mar 15, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My Thomson Top up TV box will not record. I go to the TV guide, press the R button. It then takes me to 'Planned Recordings' list. I press R again and the programme I want to record disapperas. I get...
Sounds to me like your hard drive is full. Do you use the topup tv part of the box? If not, deselect all the topup tv channels. This will free up a significant amount of drive. Failing that, you'll have to delete some of your programs, sorry!
To deselect topup tv channels;
Go into the menu option, Customise Top Up TV Anytime, and de-activate all the selected channels
Jan 23, 2010 | Televison & Video
Cannot record without watching the programme
This unit does not have twin tuner,you would have to watch another channel on the tv.
Dec 03, 2009 | Panasonic Televison & Video
I have purchased a Teac HDR2500T video recorder. I can set up to record television programme through EPG or PVR. I can see in LIST that the programme is recording, however when the programme is finshed,...
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Sep 06, 2009 | Televison & Video
Can't finalising the recorded discs, and can't record at high speed from SKY box to DVD recorder.
instruction man available on line
plug the sky output cable directly into the recorder then press record
Jun 01, 2009 | Televison & Video
LG HDD/DVD Recorder RH177
Hi. I have this machine and it will only fast transfer if the original hdd recording has NOT been edited (i.e part deleted/divided/combined). This is also in the manual p51/52.
Hope this helps.
Adam.
Feb 06, 2008 | LG RH177 DVD Recorder/HDD Recorder
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
Funai PY90DG DVD Recorder Logo
158 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
