Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Suction loss when handle is tipped back to clean carpet
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
  • 9 more comments
  • sean04 Nov 22, 2008
  • demonheat Nov 27, 2008
    when using the vacuum upright, it has lost suction
  • dbmmbyrd Nov 28, 2008
    Same problem, but mine started after the beater brush was repaired.
  • ktq76 Nov 28, 2008
    I have the same suction loss problem... I think the head is creating a seal with the carpet. Is there a way to fix this?
  • jeniferhawki Dec 01, 2008
    I have the same problem...started after repairing the beater bar which was not turning...beater bar turns now, but no suction when it's in the vacuuming position
  • chocomamamia Dec 27, 2008
    The hose has plenty of suction but when the handle is tipped back, it loses it. I have cleaned the beater bar, the hoses, checked connections, washed the filter and brushed the holes inside the cylinder but nothing has helped.
  • cwhdep Jan 03, 2009
    Great suction using the hose and tools, but when using the upright tipped back, suction is lost.
  • charleneterr Jan 06, 2009
    The hose works great with attachments, but when the vacuum is tipped back to clean carpet, there is no suction at all
  • chris ab Jan 14, 2009
    I have the exact same problem - loads of suction through the hose but nothing through the brush when the handle is back. I think there must be a problem with that flapper valve switch thingy by the wheel but can't see anything wrong with it - anyone got any suggestions??
  • kserino Feb 07, 2009
    I have the same problem as everyone else. maybe it 's a defect then?
  • 1Aubrey1 Mar 07, 2009
    Same problem here. It used to work great no matter what. Now it only seems to have good suction when using the attachments. Its only 2 years old.
Ours did the same thing. I cleaned the filter and canister thoroughly. It needed to be cleaned, but that didn't fix the problem. I removed the plate under the carpet brush bar (three quarter-turn screws) and removed all hair, lint and threads from the rollers and brush. THEN my husband found the real problem: a piece of flexible hose running from the head into the hose (on the left side when behind the vacuum) was completely clogged. The hose will detach from the head, and you can remove debris. Once that clog was removed, the hose easily re-attaches, and we had great suction once again.
Posted on Feb 14, 2009
Can any one help,
Posted on Nov 22, 2008
There is a molded plastic piece that is round (for hose to fit through) that clips into the wheel assembly and pivots or turns down towards the floor when the vacuum is being used traditionally (without attachments) and back up when not in use or upright. I believe it is to prevent the hose from "kinking". Ours cracked and eventually broke off completely. Its like haveing a hole in the hose, the vacuum completely loses suction. We can not find a replacement part. I would check this if I continued to have problems. I never thought I'd be happy to see the Kirby guy, but WOW were we!!
Posted on May 31, 2009
No suction in attachment hose. There is no clogg
Most likely cause is that the handle needs to be full upright to engage the attachment hose. If it's tipped backward, like you'd have it when doing vacuuming with the bottom unit, it's shut off. You may also want to move the handle to full upright and then back to deeply angled backward a few times in event that the mechanism is stuck or sticky. Good luck!
Oct 18, 2015 | Dyson DC15 Animal Bagless Upright Cyclonic...
Mt dyson has too much suction
Hi there, it's Jack at Dyson.
I'm sorry to hear you feel your DC40 has too much suction. This sounds unusual, and in order to help you resolve things we would need to take some further details about your machine, and the particular flooring type you're having difficulty with.
When you have your machine to hand, please call us directly so we can talk you through some simple troubleshooting checks to make sure everything is correct with your DC40. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Sep 27, 2014 | Dyson DC40 Animal Upright Vacuum -...
My Dyson DC 28 works great, until I remove the bag to empty it. I reattach it, clicking it carefully in place, but then I release the "tilt" thing to vacuum carpet, and NO SUCTION! I have to keep taking...
On the back of the Hoover is a couple of parts you can remove, one is a u bend which will trap heavier parts which resist the suction so get stuck in the bottom of this, and the other part is usually on the right at the bottom which is an acces point to the very art which you hear click. In the upright position it directs the vacuum suction up the extendable pipe, but when you pull the handle back, it should gently glide from one direction over to direct vacuum suction to the bottom plate. It's tha part which is getting stuck in the handle sucking direction. I'd check to see if it is physically damaged in any way or if something is tapped in it like a coin or something. Good luck
Nov 25, 2013 | Dyson DC28 Animal Airmuscle Vacuum 00247
It is not picking up from the carpet--the exhaust air is coming out the bottom back and not from the top handle--I was not the last to use the vacuum--I think the housekeeper used the handle hose and the...
Sorry to hear your DC28 Animal is not picking up. To check everything is correct with your machine, please ensure the filters are clean, and the cleaner is free of blockages. This guide from the Support section of our website shows the easiest way to do this:
http://www.dyson.com/support/help.asp?article=1456&product=DC28-ANIMAL
Please note the motor exhaust, where filtered air is returned to the room, is located beneath the clear bin. Exhaust air will never come out of the top of the handle.
If you've checked the machine for obstructions and are still having problems with the performance, please get in touch with us free on 1866MYDYSON, or email askdysonUS@dyson.com , so we can provide further assistance.
Kind regards,
Jack
Dyson Customer Service
Jul 24, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
Lack of suction
Do not think its motor .......Yoy need to see thats its not Cloged if so clean.......
Feb 21, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction when using the hose.
The beater bar is supposed to stop when the vac is upright. Sounds like you have a clog. There are several access points to check, fairly easy to clear obstructions.
Nov 14, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Way too much suction
Did you call Dyson?  Just call their customer service and see if there have been other complaints like yours.  I just got the same model and will be looking out for this.
Randy
Dec 02, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
1,186 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
