Question about Toshiba TP55H60 55" Rear Projection Television
Turns off - Convergence module? - Cost to repair?
For over two years the red colors would bend on the screen. When I shook the TV a bit, it would stop. Sometimes for just minutes, other times for weeks. Now when I turn the TV on, it comes on for about a half second and then turns off. Power light flashes. Based on what I've read, is it fair to assume one or both of the convergence modules is bad? I have no experience in repairing electronics, but after taking the back of the TV off and researching this part (stk392-110) I think I might be able to replace it myself for the under $10 they cost. Any idea on what a repair guy would charge to come to the house and do it? I'm definitely not hauling this thing in anywhere.
  • Scott Hasler Dec 17, 2006
    So these are all pieces of garbage that won't last long?...
    http://www.bdent.com/search/part.jsp?par...
    $13.99
    pacificsemi.com
    stk392-110 $9.99
    stk392-110T $19.79
    http://www.electronix.com/catalog/produc...
    $5.99
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
Scott H: Do you get this fix and how? My red line is off from the rest of the picture but the TV is still working. I took out the back panel and was not sure which circuit board to unplug to work on this STK part. Some boards have a double stack witjh one board on top of another board with a tall 4" standoff.
Posted on Sep 04, 2007
  • Victor William Nov 30, 2014
    It costs me over $200 to repair that 6 years ago. On the 2nd time, I repaired it myself. Just follow the tips on this web
    Three major tips:
    1) Good part: Make sure you buy the parts from a reputated electronics shop and get the higher voltage rating version if possible. Change all 3 at the same time and they should cost around $20-$30 (a few years ago).
    2) Good heat dissipation : Get good heatsink compound (very important) and spread the evenly. Does not need to be thick.
    3) Airflow: Also make sure you are TV is not sitting on high pile carpet as this will reduce the airflow from the bottom of the TV. There are air vents on the bottom near the Convergence IC/big heatsink to cool them. I raised up my TV by an inch by sticking two long 1x2 wood along the side of the TV. You won't even see them where you seat.
    Don't pay someone to repair it on this old TV. For $200, use it to buy a new TV that is quite reasonable price these days.
    Good luck.
    President:
  • 3,130 Answers
Oh beleive me you can buy STK convergence IC's for 5 bucks or 6 bucks, but they are called counterfit semiconductors and do not have the specs that the originals do, so you will most likly be in the same boat or worse off then you are now after replacement or a few months down the line. NEVER ever replace with a sub replacement, only use what the manufacturers say to replace them with. Just because they say the same numbers does not mean they are the same, cause they are not! Good Luck Please do not forget to rate this thread.
Posted on Dec 15, 2006
  • 81 Answers
Cannot buy the stk,s for $10 if U can let me know where. It may look easy to replace but believe me they are not. they will cost at least $70.00 each and labour differes with the repair place U could be looking at at least $300.00. Again if you can buy new stk's for 10.00 let me know where!
Its a 2004 61 inch big screen projection tv and the subject on screen has three colors outlining it green red blue on the outer portion of subject on screen
Tv have a problems known as a convergence pictures problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to repair it.To solved tv pictures convergence problems.The shop will cost u like $300-350 for parts and labors.
Jul 05, 2011 | RCA R61WH76 61" HDTV
The picture bends at the top and the bottom of the screen and is blurry where it bends at
The tv have a problems known as a convergence problems,it dead.Tv have colors R,G,B lines mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-65809 65" Rear Projection...
The red coler has started to curve about a third of the way down the screen. everything on the the screen is distorted and doubled in red
if your picture looks 3d it is convergence problem.
This is a do it yourself repair if you have some skill.
I will tell you what you need and have start to finish, step by step instructions for this repair along with photos, and source for parts needed(parts cost will be under 30 dollars).
reply here if I can help.
SD TECH
Oct 24, 2010 | Mitsubishi WS-55807 TV
The red field on the screen, bends within the image, creating a 3D like effect.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingnment,have colors shadows pictures or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,require replacing to fix the tv picture convergence problems.The shop,will cost $300-350 for parts and labors.
Oct 19, 2010 | Mitsubishi WS-65712 65" Rear Projection...
My picture is warped or bending in the middle
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 21, 2009 | Philips Magnavox 51MP392H Rear Projection...
PT-53wx53g Convergence issue?
Both convergence amplifiers should have been replaced at the same time. If you can get your hands on a service maual, replace both of them, and go through the convergence alignment in the manual.
Jun 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence chip
Convergence ICs cost around 15-25 each there are only two of them. I would go ahead and replace both of them because if one goes the other one will follow shortly. I would make sure that it is just the convergence IC not something else, and if its over five years old dont pay more than $500.
Nov 04, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Hitachi television repair
how do i access the convergence on my big screen
Oct 16, 2007 | Hitachi 61SWX10B 61" Rear Projection...
No power with remote or manual power switch
Your convergence module is probably bad. It is a plug in module, so labor would be lower if the convergence settings are still good. The bill would be about $300.00 If not, the labor for convergence would add to the bill. If the whole job needed full convergence the cost would be about $500 to $600. Hope this helps, Lee http://www.CrazyComputers.com
Jun 22, 2007 | RCA P60921 60" Rear Projection Television
Toshiba TP55H60 55" Rear Projection Television Logo
1,359 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
