Question about ECM Giotto Espresso Machine
No Pressure..No heat
Have an ECM Giotto Espresso machine. The water will not heat up or build up any pressure. water will come out.. but it is ice cold. I keep hearing about descaling the machine but have no idea how to do it. suggestions?
  • Anonymous Dec 11, 2008
    Same exact problem. I just replaced my pressostat...
  • Anonymous Mar 16, 2014
    My Giotto Evolution is about 14 months old and over the past month is has become increasingly hard to produce consistent shots. This is my second machine in the past 12 years. Every morning I make two separate coffees using a ***** handle and a VST 15 gm bucket. The run rate is never consistent! I find I have to change the grind repeatedly to maintain the flow rate.
    I have Mazza Mini stepless grinder and previously have never had to repeatedly change the grind to maintain the correct flow rate. I suspect this is a temperature/pressure problem. I have descaled the machine about 7 weeks ago, using a consumer descale product and the machine was stable for about two weeks after. Any suggestions.
    Problem Solver:
  • 9 Answers
Se my solution re no heat on page. pressostate or microswitch fail is easy to fix. many times the water tank is bebt out of shape with time. A twisted tank lift one side and tank is no longer resting on four points. This cause no contact with electrodes inside tank saying = no water = no power allowed. The GROUND must be established! A small piece of alu foil rolled to a ball will help to ground the electrode again. Lift the tank gently and find the two v - shaped contacts for the electrodes. Have also replaced the electronic box once :-( on friends ECM /// olev
Posted on Mar 21, 2009
I have a Giotto ECM esspresso machine. it is approximately 3 yrs old. recently when i turn the machine on, it starts heating up, but it doesn't create any pressure. any suggestions how to fix this problem.
Hi
1 solution is your vacuum breaker valve is sticking. Try opening the steam valve and see if you can start to heat again. If it does just, replace your vacuum breaker valve.
Sep 20, 2010 | ECM Giotto Espresso Machine
Air pressure excessive
that's a valve that's in line with the internal plumbing..that's all that restricts that pressure, which can build quite high.
can you provide the exact model number, please?
Mar 02, 2008 | ECM Giotto Espresso Machine
Ecm Giotto
Have you checked the Thermostat on the unit in the tank if it is stuck it will cause the tank to over heat and pop off the steam valve?? there should be some resettable overheat protectors as well. Has the preassure relief valve been replaced as well??
Feb 14, 2008 | ECM Giotto Espresso Machine
I recently moved, and when I got situated, I simply added water to the tank, plugged it in, and turned it on. While warming up, the ususal hissing noise before the pressure and temperature starts building,...
The hising is your vacuum breaker not closing. Check you heating element with an ohms meter. It should read between 14 and 17 ohms. If you get a larger or no reading its your element. It needs to be replaced.
Jul 06, 2010 | ECM Giotto Espresso Machine
My 5 year old Giotto has stopped working
The vent valve on the machine is stuck in the open position. Turn on the machine and open the steam wand until you hear a hiss or see small water bubbles from nozzle, let it steam out a little more then close wand, that should allow the machine to heat up correctly, then order a new vent valve for the machine.
May 03, 2010 | ECM Giotto Espresso Machine
ECM Giotto
sound like it need to taken apart for a good cleaning. Hard water will cause build up ..your user manual should tell you how. i have the manual. It says Hard water will cause that problem.here is the link for the manual.http://www.espressotec.com/store/pc/catalog/pdf1/ec1300_ecm_giotto_manual.pdf
Jan 02, 2008 | ECM Giotto Espresso Machine
Hey! My ECM Giotto is building up too much pressure. 2+ bars. I tried resetting it but no lick. New thermostat?
The pressostat can be full of scale. You can remove it when the machine is cold descale it and also use a litle lubricate so the part can move more easily. You migh need a new mebrane since it might have be damage but if you dong have you can cut a plastic the same round shape of the mebrane and put the both back again so that no steam will escape from the mabrane.
Feb 13, 2010 | ECM Giotto Espresso Machine
Machine is on but no pressure and no attempt to make any
Open the top panel of the machine there is a small reset thermostat, that may have have tripped, push in to reset(sometimes reset is on the element).
Mar 31, 2009 | ECM Giotto Espresso Machine
Giotto pressure valve constantly on
You must have an internal leak and your machine will need to be serviced. If you can remove the top of the machine maybe you can see where the leak is coming from and may be able to repair the machine yourself.
Cerini Coffee
Espresso machine service and Sales
www.CeriniCoffee.com
Nov 10, 2008 | ECM Giotto Espresso Machine
Wet grounds
What you see is condensed stem comming out and no water. The pump is not sucking from the tank as ther is an air bubble in suction line. Still want coffe and don't want to clean your machine??? Flick up the lever with no group in place. Steam comes first then nothing. Pump is running and - voila - water comes as air bubble is gone. (Specially the first cup , never the following ones.) Now put back the group and brew your espresso. The machine is full of scale and neds total clean - by hand./// Olev
Jun 13, 2008 | ECM Giotto Espresso Machine
ECM Giotto Espresso Machine Logo
393 people viewed this question
Top ECM Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
