Question about HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory
PRINTING BLANK when the machine isn ready, giving any command for printing even if not connected to the p.c it processes the job and then indicates printing but ultimetly in the output tray gives a blank paper
  • 432 Answers
The registration and transfer rollers need replacing.
Posted on Jun 26, 2007
SOURCE:
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
Use Printer Offline: Error Processing Command
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Jun 07, 2010 | HP DeskJet 6540 InkJet Printer
Cancelling won't stop printing -- blank pages with headers and foot notes
Dear, there is a printing command that is in the printer cache, and it is doing the job automatically. There will be a printer icon in the system tray at bottom right on the task bar of you computer, click on it, a dialogue box will appear with all the printing commands in the que and cancel all the printing commands in the que. and switch of your printer, re-start the computer. You problem will be resolved.
Best regards.
May 26, 2009 | HP OfficeJet 6310 All-in-One Printer...
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
Dell 948 printer printing not finishing print jobs
Your printer loose documents:try to reset it ,unplug for an hour.
Or you might have interferences on your wireless :DECT phone, cell phone, or even an electric device who doesn't work propely, like tv, stove, speakers many things can parasites your connection...
If nothing does your printer as issues, think replacement...
cheers
Dec 19, 2008 | Dell 948 All-In-One InkJet Printer
Blank copies
Blank copies are related to a empty or bad cartridges - Try cleaning your cartridges or replace them.
Try printing differents documents and see what happen.
Check yor printer cables
Check your printing settings
Check if your printer is "ready"
Check the connection between your computer and your printer.
Sep 06, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
HP LaserJet 1022 Printing Blank Pages
Aug 08, 2008 | HP LaserJet 1022 Printer
HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory Logo
105 people viewed this question
Clive
Clive
Thomas F. Schneider
