Question about Kenmore 92002 / 92004 Kitchen Range
OVEN FLASHES -F1- AND BEEPS, CANNOT TURN BEEPING OFF
TURNING OFF THE POWER TO RESET DOES NOTHING
  • 367 Answers
IF you already tryed unplugging it to reset the clock and it didnt fix it you must replaec the electronic control. F1 means analog to digital failure. AKA replace electronic control.
Posted on Nov 21, 2008
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
How to Get GE Oven to Stop Beeping eHow
Apr 21, 2014 | Whirlpool Ovens
What could be the problem if F1 code and beeping in GE wall oven/
F1=Touch control pad and or Clock defective.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
Jan 11, 2011 | Ovens
Displaying F1 error
Apr 04, 2010 | GE JGRP17 Gas Single Oven
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
Oven turns on by itself and F1 flashes on the digital clock
Without being able to look up the error codes for your model (number please!), I would guess that the oven control triac has shorted out or the relay is stuck on (I assume the oven runs at maximum temperature). In any case, the oven microcontroller knows something is wrong, so it says F1 and beeps for help.
Aug 10, 2009 | Kenmore Kitchen Ranges
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Wolf built-in Wall Oven 762. Convection Fans stop turning intermitantly Oven shut down with F1 warning Later restarted ? meaning of F1 warning
http://www.applianceaid.com/fault_codes.html
click the link
Dec 06, 2008 | Kitchen Ranges
Self cleaning ovens
i have the same problem. the burners work and f1 is flashing and the oven wont work. i turned the breakers off but it does not reset. i just want my oven back and i will clean it myself.
Sep 05, 2008 | Kitchen Ranges
Open Questions:
Inner part of Triple element on 790.9912940 won't turn on I just experienced the same problem I've been reading about here and on other appliance repair sites: the inner element of my Kenmore Elite's front-right triple element will not turn on, despite the control panel saying it's "on." The range is about 2 years old, just like many other people have said. Also, Sears naturally wants to charge $65 to even come look at the part, and then several hundred more for a new element. From reading other comments and after talking to Sears, it seems like there is no extra warranty or recall on this part. This triple element is apparently a defective design if I can find so many reports of this exact same issue with only a cursory Google search. Would not have bought Kenmore anyway if it hadn't come with the house, because I've heard of this kind of thing with them far too often, despite their obvious good looks and nifty features... I'd rather not have to spend hundreds of dollars just to keep my $1.2k range working properly - for that price it should have a 5-year warranty at least in my opinion. I'm going to see about removing the element and putting in a new one on my own, as getting the part itself (Sears Direct Part Number 316216702) is only about double the cost of getting a technician to come out in the first place. You can see a handy part diagram of the range top at this link, by the way: http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0610001-00003.png The element that has failed on my range is part 15B in the diagram.
Sep 08, 2009 | Kenmore 92002 / 92004 Kitchen Range
Kenmore 92002 / 92004 Kitchen Range Logo
134 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
