Need to restore my drivers
Ok i installed a new hard drive and windows xp on to it and it is missing drivers how do i get them back i tried alot of things and now i am lost
    Scholar:
  • 63 Answers
Colossus
You need to get the model information of your motherboard and the hardware inside the computer.
If this is an HP, Dell, or other retail manufacturer it is REALLY easy to find drivers.
You can download a utility called AIDA32 and it usually helps identify hardware on your system and helpd you find the manufactueres and the drivers.
Aida32 download http://majorgeeks.com/download181.html
Best Wishes
www.techvisitor.com
Posted on Nov 19, 2008
  • 101 Answers
You should have CDs that came with the computer. If you don't have the CDs, you will have to find the Make and Model of each device that needs drivers, go to the manufacturer's website and look up the drivers.
After you find them on the web, be sure to save them to CD for the future.
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Jan 22, 2014 | Belkin Basic Wireless Router
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
What drivers are need for clean windows xp install on sony vaio pcg-k37?
This model Sony came installed with a 80Gb hard disk and a 40 Gb
Do a clean Windows install on this old hard drive -
Boot up with the Windows installation CD
install Windows on the hard drive
Delete the existing Windows partition
Create a new partition
Format the new partition (full format not Quick format)
Continue installing Windows.
Mar 24, 2012 | Sony PCGK37 Notebook
Installed new hard drive (old one crashed) no sound now
You need another sound system. If it's xp it is probably ac 97. However; go to windows update, make sure you have all of the updates. Then go to the control panel, device manager and look for a yellow question mark or a yellow exclamation mark, if there, right click and click update driver or click uninstall from the system, restart the computer and windows will look for the drivers, just follow on screen directions.
Jul 08, 2010 | Gateway GT5228 PC Desktop
Windows XP won't start
for that you need winxp bootabler disk.
Tehn boot your computer with tht and go to recoverry console.
Then type in command prompt "chkdsk /r"
then press "y"
then it fixc error on harddisk.
Then after completing it restart your computer and boot with harddisk then it ok.
Jun 20, 2009 | Computers & Internet
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
1. Restart the PC. The hal.dll error could be a fluke.
2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
I had to erase reformat and reinstall xp on hard drive
your drivers are available here ; http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8250&os=WW1&osl=en&catid=&impid
download the specific drivers to your desktop (so you can find them) install in this order, chipset , sata if needed, video, audio.
make sure you check the windows updates site afterwards for all the new windows updates since your version of XP was purchased.
Regards..
Apr 09, 2009 | Dell Dimension 8250 PC Desktop
NTLDR is missing
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Open Questions:
@#$@Free1'877'778'89'69Avira Antivirus Support Helpline Number? USA 1-877-778-89-69 Avira Antivirus Support Helpline number is straightforward to use. Avira Antivirus Support phone number is open twenty four hours daily and seven days per week.Avira Antivirus support Helpline Number's agent will assist you with remote help.Avira Antivirus Support Helpline Number 1-877-778-89-69 is one of the most promosing and helpfull number of any Antivirus issue's.We are open 24*7,ready to solve your problem with just a TollFree call:-1-877-778-89-69 .Our expert team finding your issues area and solve the problem in faster and easier way.We are Happy To Help You.We are Avira Antivirus SupportUSA.A single call will change your life.just dial:-1-877-778-89-69. For any question or help:-1877~778~89~69. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number.
May 29, 2017 | Avira Computers & Internet
Computers & Internet Logo
44 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
