Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Dregdrawer Full Unit indicates "Dregdrawer Full" - I have cleaned every obvious element; anybody know where the sensor is located?
  • 3 Answers
There is no 'sensor' for this, an internal counter resets when you remove the drawer with the machine switched on and the "Dreg drawer Full" message displayed.
Make sure the machine displays this message "DREG DRAWER FULL" Do NOT turn off the machine, Pull out the drawer that the used grinds are dumped in(you have to remove the drip tray 1st) Check display - it should read "DREG DRAWER MISSING" If the display message is correct, wait 10 seconds then replace the drewer.
Message should be cleared.
If the "dreg drawer missing" does not display, you do have a bad sensor and machine needs to be serviced.
Posted on Nov 20, 2008
I found that the sensor can get blocked up with coffee powder, causing the "Dredgedrawer Full" warning to stay on. I gently slide a plastic knife blade into the sensor slot and find that this this resets it. Been doing that for a few months successfully now (it locks on Dredgedrawer Full about once a week).
Posted on Nov 26, 2008
Coffee grounds (unused) dropped into dregdrawer tray
try to make the grinder position on 2.
And where exactly is the unused coffee-in the drawer or under the brew unit? Did you try to wash the brew unit with water-fill a box with hot water and put it into box. Leave it all night and in the morning just clean on the water and dry it.
Let me know what is result when you done it!
Apr 14, 2015 | Gaggia Titanium Espresso Machine
When I turn my saeco royal cappuccino machine on then it tells me that the dregdrawer is full but it isnt full. So can anybody tell me whats the problem? Maybay the drawers sensor is broken or something?
Drawer sensor (activated by horizontal tab on left side of drawer) works on the weight (like a mini scale) of the drawer when full. The motion of the sensor can become restricted due to grinds limiting the movement upward to the default position.
If 'stuck', the sensor thinks the drawer is heavy and therefore full.
Clean it (old toothbrush, hot water, steam run from your spigot) so it moves freely and your problem should be solved.
Happy brewing!!
Sep 06, 2010 | Saeco Royal Cappuccino Espresso Machine
The sport button light keeps flashing and the millage indicator stop running i don't know how fast i'm going do anybody know what wrong
you need to replace the speedo sensor located on top of the transmission unit. Once replaced, it will back to normal
Jun 04, 2010 | 1991 Honda Accord
Dregdrawer Full
I read somewhere that there is a counter in the machine that when a certain amount of shots are done, the counter will reach its limit and tell you to empty the drawer, even if it's not full.
When I get the message I open the door, remove the drawer and it goes away once you replace it. Don't know why the machine would stop working though?
Apr 28, 2010 | Gaggia Titanium Espresso Machine
8'' electric stove top element not working
timer on what ? make, model and age of unit might be useful in forming a coherent response.
Mar 07, 2017 | General Electric Stove/Oven/Range Chrome...
Dregdrawer. miss.
Make sure the machine is clean of coffee grinds. Mine has a nasty habit of dropping them behind the dregdrawer instead of in it. Remove the central unit and give it a good clean. The dregdrawer should then slide back fully into the microswitch.
If this doesn't work, you've probably got a dud microswitch.
Nov 20, 2008 | Saeco Royal Professional Espresso Machine
"dregdrawer" is full
You must have the dregs box out of the machine 5-10 sec and the machine have to be power on.
If it still not get to work then try this:
Make sure the pin on the side not is worn, the pin goes to a microswitch in the machine.
If it is worn then try to put a tape on it to see if help.
Best regards
/Mirran
Sep 11, 2008 | Saeco Royal Professional Espresso Machine
Service error 5C00? what's that?
Service error 5C00 is a purge unit error. The purge unit like a spitoon to the printhead where is stops. There is a sensor in the purge unit; when it is blocked (usually by ink build up), that error is given. The error indicates that the purge unit may be full or at least gunked up. It may be possible to clean the purge unit and sensor to make the error go away. I base this on information learned with experience on another Canon product (Model i560). Hope this helps...
May 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
DregDrawer full message won't clear
When you need to empty the grounds draw remove the drip tray and pull out the dregs draw - don't open the side panel or turn off the machine, - It works for me!!
Feb 20, 2008 | Saeco Royal Professional Espresso Machine
Dregdrawer full
drain machine, turn off power , get vacuum cleaner nozzle into drawer slot (make sure its dry or u'll have to post a repair for vacuum cleaner repair) remove all deposits for chamber , shake and bang machine to lossen deposits. if drawer has metal clips or something that looks like sensors (does not have to have wires attached to be a sensor) clean !
Feb 02, 2008 | Gaggia Syncrony Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
1,850 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
