Question about Home
Triton opal electric shower overflow pipe
There appears to be a plastic overflow pipe situated directly behind the outlet on my electric shower. Water is continuously pouring out of it. I have tried descaling the heating chamber and a fair bit of lime scale came out of it, but it has made no difference to the water coming out of the overflw pipe. The pressure seams ok also.
Please can you help.
Regards
Rob
    Scholar:
  • 44 Answers
Hi rob the problem is due to an activated thermal overheat switch, you cannot reset this unit as once it is activated it will require a new unit, its a nuisance i agree as i come across this regularly, however its condusive of a scaled up unit so you eventually turn up the shower setting higher to get the water hotter, & inturn activates the thermal switch.
According to which model it is the part is not that overly expensive, you can phone triton direct 7 they will post a new spare to you
Kindly
Richie
Posted on Dec 15, 2008
Triton t300si shower low pressure problem
there is a fine inlet filter on the plastic pipe,remove and wash under tap pressure
Feb 26, 2013 | Home
Water coming out of small pipe next to water outlet to shower head whats the cause
its the overflow, you need to clean/descale the shower head/pipe,or have it serviced
Sep 25, 2011 | Home
I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Nov 11, 2009 | Water Pik Waterpik& Elements& Fixed Mount...
Turned on a triton trance electric shower it was working ok then it stopped coming out of the shower head and coming out of the overflow pipe at the bottom of the shower unit
The overflow pipe is a pressure relief device which is a small rubber ball that get's ejected when the water pressure inside the shower is too high. You will need to get a spare part to replace this. These generally operate because the showerhose is in poor condition and has collapsed internally, or the showerhead has become clogged up so check these things first.
Good luck.
Sep 21, 2009 | Kitchen Appliances - Others
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
My shower works. water also poors out of a tube beneath the unit
Are you talking about water still coming through the spout at the same time? What overflow pipe are you talking about? If you are talking about the spout, there is a device in the spout that when you pull up on it, the water is diverted to the shower. They have washers in them and it sounds as though the washer is worn out and not making a good seal anymore. You can buy a new generic spout to stop the water or you can take the old one apart and try to find replacement pieces. I have taken one apart and bought a new one to rob the parts off of it before. I hope this is the answer you were looking for. If not, reply to this for clarification and I will try and answer your question more clearly.
Apr 02, 2009 | Home
Triton opal 10.5kw shower runs ok apart from leaking cold water from casing not the little overflow pipe
probably needs a replacement stabiliser valve assembly- about £29 each. look in your user guide
Jul 19, 2008 | Heating & Cooling
Home Logo
2,392 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
