You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Microsoft Age of Mythology for
when i put my real deal slots game in the launch screen comes up but when i hit play i get a box...
(More)
when i put my real deal slots game in the launch screen comes up but when i hit play i get a box that says for me to put in my real deal slots disk
the problem was not fixed when i changed the setting from high to low it still did not show my units...
(More)
the problem was not fixed when i changed the setting from high to low it still did not show my units buildings unless they are in motion then i can see them
hy , i did al these steps but when i want to play this game it says put cd 2 in it , and when im...
(More)
hy , i did al these steps but when i want to play this game it says put cd 2 in it , and when im doin it it won't read it , i realy like this game so can anybody tell me how this solve this problem ?
