Question about Brother MFC-7820N Printer
Scan views fine; prints fuzzy
Scanning any document.
Latest scan - legal size, B&W, 300dpi, a survey so lines and text.
Views fine on monitor, prints out fuzzy, non legible.
Have tried printing on 2 different printers, same result.
Text and lines, look like they have grey/black shading behind them making them fuzzy and unreadable.
Looked at scanned documents from several months ago same problem.
So can this fuzzy print problem be fixed and how do I fix the older scanned documents?
Thank You!
  • 32 Answers
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Posted on Nov 19, 2008
Can I scan legal size paper with the Canon MP 240
You can scan the largest size of paper that will fit on the glass area of the scanner (the platten).
If your legal paper fits in this area or, at least the text printed on it fits well within the borders of platten, then you can scan it.
Your scan will show you a preview of the image scanned so you can see if all the text has been scanned from the original document before you save the scanned image on the computer or copy print it.
Legal Paper Size is: 8.5" x 14" (216mm x 356mm)
A4 Paper Size is: 210mm x 297mm
Letter Paper Size is: (8.5" x 11") 216mm X 279mm
This printer's Scanning Width is: A4/Letter
This printer's Scanning Length is: A4/Letter
I hope this helps.
Aug 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
When scanning printed document as an email attachment the print is not clear.
Scanning high resolution(600dpi). and reduce size 300dpi and compress image (image editing program format jpg.)
Mar 29, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
I'm having trouble scanning B&W documents with my Epson V300. The edges of the letters in the text are jagged and hard to read and there is what appears to be a crease or fold in the document when the...
You have two options for scanning text. You may explore both of them and see which is better for you. Either way, you will have to make friends with manually changing the scanning settings, because simple presets often are not suited for every case.
First is to use Grayscale mode, and a minimum resolution of 200dpi. This should give you satisfactory text quality. If you want to print the text afterwards, 300dpi would be even better. You may want to increase contrast, to get the letters more defined and eliminate most of the background toning.
Second is to use Black and White (monochrome) mode, but in this case you need to set the resolution higher, preferrably to 600dpi. Also in this case you will have to play with the Black/White threshold in order to eliminate background "dirt" appearing as black artefacts.
If you scan the documents in order to process them with OCR software, usually the OCR application will give you suggestions on how to set the scanning parameters to obtain good results.
Jan 24, 2010 | Epson Perfection V300 Film Flatbed Scanner
Cannot scan legal size documents. The scan goes through but it will only scan the letter size portion of the document and drops the rest of the text.
You likely need to install the Brother Scanner Resolution Improvement Tool. The description of the download states:
"This tool will expand the maximum scanning resolution capability and allow you to scan legal size documents."
Here is a link for the Windows Vista download
Nov 06, 2009 | Brother MFC 8840D All-In-One Laser Printer
I want to increase the size of the small drawings i do from my epson 1250 scanner to my canon 1800ip to a4 printout size is this possible.
You have to scan the pictures with a higher resolution to be able to print them in a larger format with acceptable quality.
If your default scanning setting is, say, 150dpi resolution, and you want the picture to be enlarged twofold, then you have to increase the resolution to 300dpi. If you have 300dpi now, increase it to 600dpi.
Some scanner utilities do a fully automatic scan - then you have to find the automatic scan settings and change the default resolution. Or better yet, find an option for a non-automatic scan, where you are presented with various options after the preview scan has been done. There you can usually set the desired size, resolution, improve contrast, sharpness etc.
Generally, the higher the scanning resolution, the more detail you have on the picture, and the higher magnification you can obtain when printing without quality loss.
But there's a catch - a picture in higher resolution produces a bigger file on disk - the file size grows faster then the resolution - a two times bigger picture will be four times bigger on disk. So you have to make sensible choice.
Nov 06, 2009 | Canon Office Equipment & Supplies
Scanning a legal size document
Move the document feeder front guide towards the rear of input tray, line up with 8 1/2" marking. This should inform the machine to register for 8 1/2 x 11 or 8 1/2 x 14 originals>fed lengthwise.
Jun 01, 2009 | Canon iR 2022i Printer
We have a canon MP610 printer scanner combo, I work in a dentist office and am trying to scan a x-ray. When I do it is'nt picking up the detail very well at all. I think I need to adjust the settings but I...
the only way to get a little more detail out of this printer with x-rays is to INCREASE the DPI resolution. there are no other adjustments that are abailable.
The Scan Settings dialog box opens when you click Specify... on the Scan/Import Documents or images screen.
The Scan Settings dialog box allows you to specify advanced settings for scanning.
Document Type
Select the type of document to be scanned. To scan photographs, select either Color Photo or Black and White Photo. To scan text documents, select either Color Document, Black and White Document, or Text(OCR). To scan magazines, select Magazine(Color).
Document Size
Select the size of document to be scanned.
Auto Detect: Detects document size automatically.
Auto Detect(Multiple Documents): Select this when scanning multiple documents at one time.
Select Stitch-assist to scan the left and right halves of a document separately and combine them back into one image.
Reference See the section below for details.
Scanning images Larger than the Platen (Stitch Assist)
When you select Custom, a dialog box in which you can specify the document size opens. Select a Unit, then enter the Width and Height and click OK.
Important When you select Auto Detect the position or size of the image may not be scanned correctly depending on the document. In such a case, specify the document size, such as A4 or Letter according to the document to be scanned, and align a corner of the document with the corner at the arrow of the platen.
When you select Auto Detect(Multiple Documents) allow 3/8 inches (1 cm) or more space between the edges of the platen and the document.
If not, some images may not be scanned at the correct positions and sizes.
You cannot select Auto Detect(Multiple Documents) or Auto Detect when Document Type is Text(OCR).
Scanning Resolution<<<<-------------------------------------------------------------<<<<<<<<<<
Select the resolution at which to scan documents. The following scanning resolution can be specified:
Text(OCR): 300dpi, 400dpi
Others: 75dpi, 100dpi, 150dpi, 200dpi, 300dpi, 400dpi, 600dpi
The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail. At high resolution, scanning takes longer and file size becomes larger than usual. See the section below for details on resolution.
this should answer your question , feel free to post here agian if you need more help.
Regards, and thank you for using fixya.
Oct 23, 2008 | Computers & Internet
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Scanning Legal Sized Documents
1. From the MP Navigator screen, select "Scan with Scanner Driver" in lower left corner.
2. When in ScanGear MP, select the Advanced Mode tab
3. At Input Settings, select Document (ADF) for document type
4. Set paper size in next window
5. Click Scan button at bottom
May 01, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanning problem to .pdf
Have you tried FoxIt Reader?
plz re install adob but before that plz un stall it from the control panel
Mar 04, 2008 | Computers & Internet
Brother MFC-7820N Printer Logo
399 people viewed this question
James Cagle
James Cagle
Jim Keysor
