Question about HP Office Equipment & Supplies
I took the old tri-color cart. out and I can't get the new one in,it seems as though there is not enough clearance on the top. It won't just slide in. Help Please. thanks, Kathi
  • 57 Answers
Hi kcirasuolo,
try do the following:
1\ the sequence of pluging the ink cartridge by reverse the action you do for unpluging it.
2\ some connecting pins conflict inserting the cart. put piece of paper just infront of pins then insert
the cart. then withdraw the paper and go a head.
hope this helpful for you,
thanks
Hamedo
Posted on Nov 19, 2008
Printing very slow and black ink Looks off color
what you do with any inkjet is take all the carts out
so you eject the carts position then remove the mains
so its stays in park
slide a bit of sugar paper {blotting paper} under the cart head
then put a large bit of cotton wool into the colours cart housing
and soak it through with 30-50mL of IPA from the local chemist
and then fold it all shut and place a damp towel over the printer
too let it all soak in
then once you remove the cotton and put new carts it will work
most printers have a soak away for old ink if you have an inkjet you have well used and well then replace it with a modern 70 quid all singing all dancing model
so repair with IPA or replace with new
i prefer colour toner ...laser prints
Mar 26, 2015 | HP Photosmart 5520 e-All-in-One -...
Slide tray won't turn and accept slide --the arm moves up and down but that is about all.
Sounds to me like one of the return springs has either stretched out or fallen off. There is no easy way to diagnose this.... takes hands on from an experienced tech. The Slide Lift Lever has to come up high enough to put the slide back into the tray, plus give enough clearance for the tray to rotate. I sure hope this helps. Jim
May 08, 2012 | Kodak Carousel 4400 Slide Projector
I'm trying to replace the failed water pump for my 2005 grand caravan. I've removed the pully bolts and housing bolts and moved the pully inward between the pump housing and the hub, but don't seem to have...
you can pry the engine over.. there will be just enough clearance to get
it passed the frame... just be carefull when prying it over not to slip cause you'll break the water pump on installation if the engine rocks back.
Feb 12, 2010 | 2005 Dodge Grand Caravan
Error message reads: left cartridge incorrect.
hello there :
this error refers to the black ink cart not being detected .
possible the new cart has a some fault on it ., u can confirm it by checkin for any defetc , leak on the cart itself or test the printer with another black cart , (if u hav one ).
*if the old black cart is still detected by the printer though the ink is low ...then jus call dell tech support ., with the order # for ur purchase and the cart replaced .
each dell cart u buy has 2 yrs warranty on them .so use them
hav a gooday !
Jul 19, 2009 | Dell 924 All-in-One InkJet Printer
Problem with replacing color ink cart. #5
Is it the right Cartridge you are trying to install please check and then check if the sensors are working.
Mar 31, 2009 | Lexmark X2600 InkJet Printer
Kodak inkjet printer 5300
hi, for you to take out the printhead of your 5300, pls follow the steps below:
>open the access door(the one you open when u change cart)
>wait for the printhead to move to the center
>take out both black and color cartridges
>on the part where you took out the black cart, there are 2 small metal pins/thongs, on top of those pins, there are 2 rectangular holes. just put your indez finger on one of the hole
>slide your finger up until you reach the ceiling of the printhead
>now, your finger should be on the upper leftmost corner of the printhead, you would feel a latch there
>just press the latch upward to release your printhead
>take it out
>install your new printhead
taadaa!!! after closing the access door you will have to calibrate your printer just follow the steps on the printer screen.
hope this helps!!ciao!
Oct 22, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
I don't know how to change the ink in Canon mp600
Switch on the printer. Open the front output tray. Lift the lid and the glass platen. The ink cartridges will slide into view and be lit up in red. Any ink needing changing will be flashing.
Press the white handle to release the cartridge. It will stop flashing.
Tilt it up and pull towards you to remove. Remember how you do this as the new one needs to go back in the same way.
For the new cartridge: -
Open the packet and peel off the orange protective film.
Carefully remove (twist off) the orange protective cap.
Do not touch the electrical contacts on the cartridge.
Do not shake the cartridge.
Insert the new cartridge in reverse to how you took the old one out.
Push it down to lock it in place, it will light up when correctly inserted.
Close all the covers and dispose of the old cartridge safely and responsibly.
Dec 06, 2007 | Canon PIXMA MP210 InkJet Printer
Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
21 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
