Replaced faulty motherboard with similar one (203966-001) re connected everything and powered up, all fans running but no response on mouse or keyboard. No signal to monitor.
Check the memmory very well remove it and re attach it back if the same then find another ram and see what happend again.
IF THE COMMUNICATION PORT FOR YOUR DEVICE IS NOT UNBOARD THAT IS IF THE KEYBOARD, MOUSE AND YOUR VGA CARD ARE THE REPLACEABLE ONE, TRY TO CHANGE THOSE CARDS THEY MIGHT NOT OK ANY MORE. IF YOU STILL HAVE SAME PROBLEM THEN THE MAINBOARD IS NOT OK, ALSO, YOU CAN CHECK YOU MEMMORY CARD THAT IS RAM IF YOU DON'T ATTACH IT PROPERLY IS CAN CAUSE THE PC NOT TO BOOT. IF IS RAM FAULT YOU WILL BE HEARING SOUND FROM YOUR BOARD, ATTACH IT PROPERLY.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
hope this helps you
the leads from your
are not faulty or just replace them they could be faulty
floppy have secure connections and are not faulty or just replace them they
could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its
cycle and have an end to function properly
even something as small as an electrical extension or a
faulty fan lead can cause this problem
computer needs all of the data and electrical current to travel through every
device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will
fail before your motherboard or your hard drive if its a flat ribbon 40 pin
type IDE replace it this will be the first to fail check all electrical
extensions make sure they are securely seated even the cd/dvd floppy drives
need to have current go through make sure these drives are working
hope this
helps
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive
the leads from your
and are not faulty or just replace them they could be faulty
and are not faulty even the electrical extensions or just replace them they could
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error hope this helps
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Many thanks for your help, mouse, keyboard and VGA are all part of motherboard but I will re check all other pieces as you suggested,
Regards.
