Question about Dynex Strip-Cut Paper Shredder
Shredder just stopped working does not run or click or anything .
I took it apart and jumped out the safety awitch but it still sits stoicly silent.
will not run in any position
Model DX-op-102991
bought from Best Buy about a year ago? Cannot find papers.
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Dynex shredder DX-PS05CC: purchased at
If it has been under 30 days take it back to best buy and tell them what is wrong. Then exchange it for a new one.
Posted on Dec 20, 2010
Do you sell the safety interlock switch for the TS4500, model no. PS-067/B?
http://shredderparts.com/tech-solutions-1.php
If you could take it apart, you could bypass the interlock. I would not do this if you have children, unless you buy a lockout box.
I would try and glue the pin with superglue.
Aug 16, 2015 | Tech Solution TS-4500 Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
Popcorn maker stopped working while popping corn
cheap made in communist china quality. took mine apart, looked at the awitches, wiring, heat sink, etc and threw part of it in the recycle bin and the rest in the trash can.
Apr 28, 2010 | Helman Group RPH-625 Popcorn Maker
Ativa X1000 paper shredder that doesn't turn on
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
Nov 10, 2009 | Office Depot Ativa DQ60M Shredder
Shredder rollers do not turn; motor works good; all gears go arou
Will it work in reverse? Can you see the gears are they all moving? Is there a set pin?
Apr 03, 2017 | Adler Royal HT500X Shredder
Shredder won't run
I had similar problem. I took unit apart and checked the motor by hotwiring it after checking voltage coming off the circuit board connections that the motor is connected to. Motor did not run until I tapped it a couple times with a hammer. Seems ok now.
Feb 16, 2009 | Office Equipment & Supplies
NoviTech Paper Shredder will not feed paper forward.
I had the same problem with my Novitech Model: PS-026/B2 only working in reverse but not forward. So I decided to take it apart and see if I could find any loose wires, broken parts etc. Keep in mind I am not a paper shredder mechanic, but I was able to fix it, at least for the time being, and here is how:
1. Unplug the machine, and I mean it. Make sure you unplug the machine before you start any fixin'. Unplug the machine!
2. I unscrewed the 7 screws located at the bottom of the case
3. I carefully separated the cases and made sure I did not allow any tension on the few wires that span the case halves
4. With the can of electronics duster I use for my computer keyboard, I sprayed all of the electric contacts, making sure I did not spray any of the grease at the gears. I poked the straw in all of the switch housings and the motor.
5. If you feel a little adventurous, you can remove the 6 screws that hold the cover and safety switch in place. At this point pay attention to how the safety switch arm is positioned ( take a picture if you have to) so it will be in the correct position during assembly. Remove the cover and look for anything that could be caught in the shredders. Remove any foreign matter with tweezers or needle nose pliers. Replace the safety switch and cover, make sure the switch arm is in the same position before you took it apart.
6. Put the two case halves together making sure there are no wires pinched inbetween. Put the seven screws back where they belong and tighten snugly ( do not over tighten cause you will break the plastic, guaranteed!)
7. Place the machine on the waste bucket and plug it in. And voila the motor should start buzzing and humming like it was brand new.
Aug 27, 2008 | Fellowes DM15C Shredder
Ativa SPL 1506X not working
I had the same problem. I took the machine apart and found out that the main gear running the rollers was defective. All of the cogs were broken or worn out, If you can find parts it can be fixed?
Nov 29, 2007 | Office Depot Ativa DQ60M Shredder
Aurora Electronics AS1018CD Shredder
Guys,
Here is an update of the problem:
Using the shredder for continuous extended periods causes the motor to overheat in which case the motor just shuts off automatically.
Leave it for a while to cool down and resume normal usage - this should make it work again.
There is a switch inside the shredder that needs to be activated by a notch in the waste basket. Take extra care to aligh the notch with the slot otherwise the shredder will not work.
No theres the fix!
Jul 08, 2007 | Aurora Electronics AS1018CD Shredder
Dynex Strip-Cut Paper Shredder Logo
37 people viewed this question
Top Dynex Office Equipment & Supplies Experts
tony wahlman
tony wahlman
ray gallant
Are you a Dynex Office Equipment and Supply Expert? Answer questions, earn points and help others
