Question about Brother MFC-7820N Printer
Scan prints out fuzzy; views fine
I've been using my 7820N for quite some time, no problem with scanning or printing out the scans.
Today,I scanned a survey plat, some writing, mostly lines document, B&W, legal size, 300dpi to email out. Saved to file on hard drive then emailed out.
Receipeint said document could be viewed and looked fine, however when they tried to print it had fuzzy lines and was not legible.
I went back and looked at scans from several months ago, same problem.
It is like all the text and lines on the document have a grey/black background which makes them appear fuzzy.
Have looked in manual and CD with unit..can't find anything concerning even scanning troubleshooting for this unit.
Put new toner in a few weeks ago, hoping that I don't have a bad unit now?
Thanks for any help.
2 Suggested Answers
713printech
  • 32 Answers
SOURCE: Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Posted on Nov 19, 2008
How do I fix this: Printing works but suddenly Scan function doesn't work?
I am a Brother employee working for the software technical support department.
We have a solution for your scanning issue posted on our solution site.
Description of Problem 100000024547
I am unable to scan in Windows 7 using the Wireless Network connection. What can I do?
Brother Software Technical Support
http://www.brother-usa.com
Jun 29, 2014 | Brother MFC7860DW AllInOne Laser Printer
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
I see others had this "check cable" problem when trying to scan on the Brother MFC7820N. Has anyone found a solution? I downloaded all the manuals, but this particular problem is not mentioned in the...
scanning relates to twin drivers and interfaces, assuming the software being used is from the same manufacturer their should not be an issue with it if you reinstalled the twin drivers and software.
Dec 22, 2009 | Brother MFC-7820N Printer
How do I scan photographs on my Brother MFC-7820N. I've never used this feature. I have a Mac computer.
Hi friend,
You just install scan software in your computer. scan option will visible on your desktop then click on your scan option then ...you can scan your document.......
Dec 20, 2009 | Brother MFC-7820N Laser Printer
Konica Minolta bizhub 6500 pro/Fiery controller scanning problem
Hello a Fiery print controller is basically a computer, which needs to be rebooted once a week to get rid of temp. files. Try shutting down each fiery every Friday and restarting Monday morning and your problems will be resolved. What model Fiery's do you have (IC-408, IC-901),? let me know which model and I can see if their is a patch to correct this issue. dave.herron@att.net PS: I am full line KonicaMinolta dealer
Nov 24, 2009 | Konica Minolta Office Equipment & Supplies
Nov 19, 2008 | Brother MFC-7820N Printer
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Sep 29, 2008 | Brother MFC-7820N Laser Printer
Stripe on receiving fax Brother MFC 7820N
I had the same problem, and I just fixed it.  It was a tiny little black dot which was stuck to the glass where the document feeder passes the paper to.  First you need to figure out where the line is on paper with respect to the paper, and just carefully run your finger on the glass to see if there is something on the glass.  I removed it, cleaned the glass, and anything which I run through the document feeder is now fine.  Hope this helps.
Aug 15, 2008 | Brother MFC-7820N Printer
"Scanning in progress" reported even when I'm not scanning anything
You need to install the print driver and Sharpdesk before you connect the USB cable.
Dec 10, 2007 | Sharp AL-1642CS Copier
Brother MFC-7820N Printer Logo
52 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
