Question about Pelonis WM-HO202C Oil Filled Radiator Heater
Pelonis HO-0128 makes strange noise
It sounds like the oil is squirting through some interior part. The noise lasts for a few seconds. The unit is not leaking, but I'm concerned that something is wrong with it.
Ty in Baltimore
  • 3 Answers
Nothing wrong with it. This is a normal sound made as the oil heats. As the heater heats up, the sounds should subside.
Posted on Feb 23, 2009
    New Friend:
Mine does that too. not to stated that our noise is one in the same, but I have located my high pitch noise coming from the controls (not the actual radiating heated part). I can quickly get rid of the sound by flipping the control setting from high to medium, then back to high. I too am concerned that there might be something inherently wrong with the heater, and that it might not last, or worse, catch fire later on. I will be returning and getting a replacement for it today. Got 2 of these heaters from Wally World, one is noisy and one is not.
Posted on Nov 07, 2016
Why wont 1996 Honda prelude start? No power at all. Turn key on lights (bells and whistle) so to speak work for a second. Now nothing no power
The battery sounds like it's dead, it may have enough power to make noise for a few but it not charging. May also be the alternator going bad and causing the battery not to fun
Apr 24, 2014 | 1996 Honda Prelude
Pelonis oiled filled heater ho-0218 won't heat up
burnt thermo fuse or element. be sure to connect any wires tightly if you replace thermo fuse. test it with a mulimeter should show less than 1 ohm. no you do not need to add oil, if the unit leaks throw it out.
Mar 24, 2014 | Pelonis Heating & Cooling
Model HO-0250H, heater makes a pair of snapping noises one after the other, perhaps from expansion/contraction. Heater is two months old.
The unit uses oil to create residual heat. The oil can contain small amounts of moisture and when the unit heats that moisture turns to steam, Steam has a great expansion ratio. When the steam condenses back to moisture it can conglomerate into large water droplets instead of being dispersed. This means that when it heats back up the steam expansion is more radical and makes noise. Unless the unit starts leaking oil, it is fine to continue using it.
Feb 20, 2014 | Pelonis Heating & Cooling
Manual for pelonis oil heater HO 0228D?Digital.
The manual is NOT at the lazy link above. This is genera l link for SOME Pelonis oil heaters but not this specific one HO-0228D
Dec 10, 2013 | Heating & Cooling
Need replacement caster wheel unit.
I found them here:
http://pelonis.com/parts.htm
Feb 20, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
I need a switch for my heater,how do i order the on and off switch for my oil heater pelonis-model#Ho-157c0109
http://www.pelonis.com/service_first.htm go to this link and about the second paragraph down are the instructtions for ordering parts, getting ready to do the same thing myself.
Feb 09, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
Mine is only a few months old. It is a Westpointe radiator type. The orange light is lit. It just doesn't heat anymore. D. Weaver/ DWeaver272@aol.com
if you dust sweep vacuum around these heaters they pick-up small particals of dust which rises up thru the heater and get deposited on the curcuit board and wiring thru convection and they go into default mode, clean thoroughly, make sure it's unplugged be fore you start
Jan 31, 2010 | Pelonis Oil Heater HO 157
Pelonis ho-0222w not working
i opened the unit and found the problem was in the thermal limiter(it burned) so i am going to change that part
Oct 22, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Electric oil filled model #ho-301
There is no pilot light. It is an electronic unit.
Sep 29, 2008 | Pelonis WM-HO202C Oil Filled Radiator...
Pelonis WM-HO202C Oil Filled Radiator Heater Logo
1,719 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
